Vladis Korobov wrote:
> I work with EPICS R3.13.1, vxWorks 5.3.1.
> I started to work with Power PC board (mv2306). When I tried to build
> EPICS base I got following compilation error in base/rsrv:
There is probably due to a known problem with the vxWorks header files
when building for Tornado 1.0.1 on the PowerPC. The fix for this has been
included in the R3.13.2 configuration files, and involves changing a line
in config/CONFIG.Vx.ppc604 so the following definition appears:
ARCH_DEP_CPPFLAGS = -DCPU=PPC604 -D_GNU_TOOL -DTRUE=1
The -DTRUE=1 is the important factor here; the architecture-specific
var-args header file for the PowerPC requires that the TRUE macro be
defined, which isn't always the case.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- EPICS R3.13.1 and Power PC Vladis Korobov
Re: Who is using what EPICS version Janousch Markus
Re: compiler bug in unpatched Solaris C++ 5.0, Visual C++ Kay Kasemir
<2000>
2025
2026
utilities for counting and sorting .db files Rozelle Wright
<2000>
2025
2026
