1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA gateway compile on Linux
To: "Hammonds, John" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 27 Mar 2000 12:28:47 +0200 (METDST)
John,
unfortunately I have to say that right now the CA Gateway is in a state,
which is ... transient.
  > I am using epics3.13.2 and the 3/8 distribution of the extensions
  > from APS.
I don't know what the "3/8 distribution of the extensions" is.
Officially there is no extensions distribution, as all the tools which
used to be in there are unbundled now.
I don't know which version of the CA Gateway you are trying to compile.
Note that there has been a ... disadvantageous development which led to
the current situation that the CA Gateway only compiles with a patched
version of base that is not under CVS control. I ran into my head into
different walls when trying to make some improvements to the Gateway.
Several people are helping now with getting this back on the track.
The current version of the CA Gateway still contains a few bugs. It is
still under development, so there's neither real documentation nor
proper support. It is known to compile under Solaris and HPUX (using the
patched base version), as far as I know it has never been compiled under
Linux.
If you still want to join the club (and are not afraid of getting your
nose hurt) ... welcome.
But if you are primarily interested in _using_ the CA Gateway, I would
suggest getting the Solaris executable. Simply waiting for the Linux
version might do the job. (I.e. if you have enough time...)
If you really want to know the gory details, Marty Kraimer or Ken Evans
might want to share this exquisite knowledge.
  >   It seems that I can get rid of the errors for getEventsProccesed/Posted by
  > commenting out
  >   USR_CXXFLAGS += -DCAS_DIAGNOSTICS
This flag is related to the patched base version and throws errors if
used with a regular base.
  >   In Makefile.Host but I still have the sigignore message and I fail at the
  > next step.
This seems to be related to compiling under Linux. I don't have any clue
about this.
Hope this helps, anyway....
Ralph
CA gateway compile on Linux Hammonds, John
Prev: CA gateway compile on Linux Hammonds, John
Next: Re: building site specific vxworks objects Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CA gateway compile on Linux Hammonds, John
