re...
> I've run into a strange problem with a database. In working with the scan
> record, I need to have Wait records that poke the PROC field in the scan
> record.
> When I do so directly with OUTN in the Wait record, it works as expected.
> If I forward link the Wait record through some other records to a CalcOut,
> all the intermediate records process successfully, but the Scan record does
> not respond when the CalcOut processes. If I point the OUT field of that
> CalcOut at somewhere else, it behaves properly, so the problem seems
> somehow due to the Scan record.
> The only difference I can see is the the OUT link in the Wait record is a
> dynamic link, while the CalcOut has a standard CA link.
> Why do they behave differently ?
One possibility is that dynamic links are implemented with channel-access
calls, while standard links may be database links or channel-access links.
With database links, it's the link's job to decide whether or not processing
is to occur. If you want to process a record with a link, the link attribute
must be PP. (Exception: if the field you're writing to is inherently PP, then
the link attribute CA will also cause processing.)
Tim Mooney
- Re: All outlinks not created equal?? Brian McAllister
Java Chip Watson
<2000>
2025
2026
<2000>
2025
2026
