Tim Mooney wrote:
> One possibility is that dynamic links are implemented with channel-access
> calls, while standard links may be database links or channel-access links.
> With database links, it's the link's job to decide whether or not processing
> is to occur. If you want to process a record with a link, the link attribute
> must be PP. (Exception: if the field you're writing to is inherently PP, then
> the link attribute CA will also cause processing.)
The link is PP. It still doesn't work.
Besides, shouldn't writing directly to the PROC field make the question of
whether the link decides to process the record irrelevant ?
Brian McAllister Application Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
- Re: All outlinks not created equal?? Tim Mooney
EPICS question: upper/lower voltage check Johann M. Heuser
<2000>
2025
2026
Re: All outlinks not created equal?? Ned Arnold
<2000>
2025
2026
