1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS question: upper/lower voltage check
To: [email protected]
Cc: [email protected], Lars Ewell <[email protected]>
Date: Thu, 30 Mar 2000 07:49:34 -0600
"Johann M. Heuser" wrote:
> I know already that EPICS database fields HOPR and LOPR should be used to
> check the demanded voltages for upper/lower boundaries. However, it appears
> to me that in our high voltage record there are no such fields yet. They
> are not listed when I print records on the crate controller.
> I append the definition file of the high voltage record that we are using
> to this message.
HOPR,LOPR just happen to be the fields normally used for display limits and
DRVH,DRVL the fields for control limits. This convention is followed by most if
not all record types supplied with base but it is just a convention.
It is the record support module that implements limits. In particular the record
support routines get_graphic_double, get_control_double, get_alarm_double.
Thus to solve your problem your high voltage record support module must
implement at least get_graphic_double.
See "Chapter 8: Record Support" of the Application developer's Guide for
details.
Marty Kraimer
EPICS question: upper/lower voltage check Johann M. Heuser
Prev: Re: EPICS question: upper/lower voltage check Burkhard W. Kolb
Next: Re: telnet based device support Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: telnet based device support Jim Thomas
