1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Daylight Savings Time
To: Robert Willson <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Apr 2000 12:18:00 +0200 (METDST)
  > I noticed that my IOC's timestamp does not recognize DST, even though in
  > my resource.def file I select a host that has the correct time.  Is there
  > another modification I must make in order to correct this?
With all reasonable time(stamp) systems timezones and daylight saving
time are entirely a matter of _displaying_ the time(stamp). So your IOC
timestamps are always absolute UT, the IOC doesn't know anything about
your timezone or DST issues.
If your host environment defines reasonable values for TZ and
EPICS_TS_MIN_WEST, your CA client should display correct timestamps.
If you want the EPICS base supplied "date" command on your IOC to work
correctly, you will have to set the EPICS_TS_MIN_WEST and TIMEZONE
environment variables from your startup script (this is my central
Europe example):
putenv "TIMEZONE=MET::-60:032602:102902"
putenv "EPICS_TS_MIN_WEST=-60"
Hope this helps,
Ralph
Re: Compiling extensions Albert Kagarmanov
Daylight Savings Time Robert Willson
Prev: Daylight Savings Time Robert Willson
Next: 2nd announcement on EPICS collaboration meetin in KEK. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
