1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tnet driver
To: [email protected], [email protected]
Cc: [email protected]
Date: Mon, 17 Apr 2000 13:40:14 -1000 (HST)
Thx Nick
I'll take it and, I think I can solve the problem. I had to do a similar
thing for some motor control on an instrument. After I test it I will
give it back.
FTP?
AH
> From [email protected] Mon Apr 17 12:39:02 2000
> Hi Alan,
> > Has anyone ported the tnet driver to Unix?
> I did a bit of work on this a few months ago. It was fairly simple - it
> just needed a new initialization routine, everything else worked. I only
> tested it on Solaris. I can let you have the code.
> However, I ran into a problem and never got back to it - so I never used
> it with real hardware. I was always meaning to ask tech-talk about it, so
> here goes.
> Does anyone have a good set of routines for turning off line mode in a
> standard Unix terminal driver (i.e. turning on the equivalent of the
> VxWorks OPT_RAW mode). My problem with the tnetDrv code was that I
> couldn't get the psuedo terminal to go into character mode. I looked
> through all the ioctl codes on Solaris and couldn't find anything that
> looked right, but on the other hand most of the standard communication
> packages use character mode and so it obviously can be done - I just
> couldn't find the codes. The answer must be bleeding obvious, but since I
> have never done this sort of thing before, I got stuck.
> So, can someone help me.
> Cheers,
> Nick Rees
> Joint Astronomy Centre               Ph:       +1 (808) 961-3756
> 660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
> Hilo, HI.  96720                     Internet: [email protected]
Prev: Re: tnet driver Nick Rees
Next: Re: tnet driver Jim Thomas
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: tnet driver Jim Thomas
Next: MATLAB Song, Jinhu
