Hi all,
I wanted to use the aao (array analog output) record and noticed a
problem: when I put an array to the channel that is shorter than
the original NELM value, the NELM gets set to the number of put
elements.
A search in the tech-talk archive resulted in the following hit
(from April, 1996!):
>From: "Eric Bjorklund, NPSM" <[email protected]>
>Date: Thu, 11 Apr 1996 12:19:54 -0600 (MDT)
>Subject: Possible Problem with aao Record
>Message-Id: <[email protected]>
> We have discovered what may be possible bug with the aao record. The
> problem appears to be in the "put_array_info" routine, which stores the
> number of points to write in the NELM field of the record. The problem
> with this that if you write less than NELM points to the aao record,
> any further connections to this record get the new, lower, value of NELM
> (through "cvt_dbaddr" or "get_array_info") and are no longer able to
> write as many points as the record originally specified.
> My questions are:
> o Shouldn't "put_array_info" be updating the NORD field instead of the
> NELM field? (if so, it means we should probably change the code in
> devAaoCamac.c as well).
> o What is the correct value, NELM (the capacity of the record) or NORD
> (the number of points actually written) to return from "cvt_dbaddr"
> and "get_array_info"?
> o (and, BTW... shouldn't SIOL be defined as an OUTLINK on an aao
> record?)
> Eric Bjorklund
> AOT-6 (LANSCE Operations)
> LANL ([email protected])
I tried the changes that Eric proposes and then the aao seemed to work
as I expected.
Have I missed something, is there a real reason for that behaviour or
have the fixes been left out from the distribution (I am using 3.13.2)
by mistake?
Timo
Timo Korhonen PSI (Paul Scherrer Institut), SLS
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
- Re: aao record behaviour Marty Kraimer
Fast Ethernet and Baja Alastair Borrowman
<2000>
2025
2026
<2000>
2025
2026
