On Fri, 28 Apr 2000, Marty Kraimer wrote:
> At aps we have not used the aai or aao records. Thus I fear making changes. If
> You and Eric can agree on changes (starting with the 3.13.2 version) I will put
> the new version in the next release.
Eric (Bjorklund), if you see this please comment!
I could use the waveform record (or genSub record) to achieve what
I need (sending a waveform to an arbitrary waveform generator), but
I took a look at the aao record because a) waveform record is obviously
intended mainly for input and b) the aao record was there.
However, I am willing to implement the changes and test them. It is
not so nice to have things in the distribution which are obviously broken.
> Here is another problem for aai and aao.
> The init_record looks like
> if (pass==0){
> if(paai->nelm<=0) paai->nelm=1;
> return(0);
> And then it waits for device support to allocate space for the array during pass
> = 1. This can lead to severe problems since storage MUST be allocated during
> pass 0. If another record has a link to the array and this record gets
> initialized before thye array record bad things will happen. If you and Eric
> decide to fix the problem I have an idea that may work. It dose mean, however,
> that associate device support also needs to be modified.
For me it is easy to modify what I have now, because it is in the
beginnings. Could people who are using aai/aao comment on the implications
of changing the record support code?
Timo
Timo Korhonen PSI (Paul Scherrer Institut), SLS
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
- Re: aao record behaviour Marty Kraimer
EPICS training at Los Alamos week of June 5th Leo Dalesio
<2000>
2025
2026
Re: aao record behaviour Eric Bjorklund
<2000>
2025
2026
