Eric,
thank you for your reply and sorry for my late response.
On Mon, 1 May 2000, Eric Bjorklund wrote:
> So, in response to my original questions:
> > o Shouldn't "put_array_info" be updating the NORD field instead of the
> > NELM field? (if so, it means we should probably change the code in
> > devAaoCamac.c as well).
> Yes, I believe it should.
> > o What is the correct value, NELM (the capacity of the record) or NORD
> > (the number of points actually written) to return from "cvt_dbaddr"
> > and "get_array_info"?
> For an output record, these routines should probably return NELM (the capacity
> of the record) rather than NORD (the size of the last write). I believe that
> is how the aao record works now.
I thought so, too. But looking at the waveform record, the get_array_info
returns NORD and cvt_dbaddr returns NELM (in a dbAddr struct).
The Application Developers guide says for get_array_info: "This routine
returns the current number of elements and the offset of the first value
of the array." For cvt_dbaddr: "This routine can change any combination of
the dbAddr fields...". What should be returned in the dbAddr->no_elements
is not specified, but to me it looks like it should be NELM.
What should the correct behaviour be?
> As I understand things now, record support needs to be the one allocating the
> buffer space since the device-support record_initialization routine only
> gets called during pass=1. This particular bug has not been a problem for
> us (yet), but I can see where it could be. I'd be interested in seeing your
> solution Marty.
Me too!
> We have a grand total of two (2) device support routines for the aao record,
> so it would be no big deal for us to change the way it works. I'd vote to
> go for it -- particularly since the init problem could be pretty nasty.
I would prefer that, too. I have one device support that I started
writing last week.
> The comments on the aaoRecord.c code indicate it is from Jefferson Lab
> (the facility formerly known as CEBAF). So I would guess that is where
> the most investment in aao records resides. Any comments from that front?
I would also be interested...
best regards,
Timo
Timo Korhonen PSI (Paul Scherrer Institut), SLS
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail: [email protected]
- Re: aao record behaviour Marty Kraimer
- Re: aao record behaviour Eric Bjorklund
Tcl/Tk and JAVA Channel Access Extention Leonard J. Reder
<2000>
2025
2026
<2000>
2025
2026
