1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aao record behaviour
To: Eric Bjorklund <[email protected]>
Cc: [email protected]
Date: Wed, 03 May 2000 12:40:02 -0500
Eric Bjorklund wrote:
> My question here is that since we're mucking with the aao record anyway,
> wouldn't
> it be better to have the record support module allocate the buffer during
> pass 0
> based on NELM and FTVL?  Then the only device support change would be to
> *remove*
> the buffer allocation code.  We would, of course, have to be sure that FTVL was
> set correctly in each of the records -- for me that would be no problem (and I
> suspect it wouldn't be for Timor either at this point).
Will this work with all device support attached to aao?
It sounds like the best solution if it works. Unless someone out there objects I
say use this solution. It does mean any device support has to be changed, but
this can be stated in the release notes.
Marty
Re: aao record behaviour Korhonen Timo
Re: aao record behaviour Eric Bjorklund
Prev: Re: aao record behaviour Eric Bjorklund
Next: Arbitrary waveform generator Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: aao record behaviour Korhonen Timo
