1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA and arrays
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Thu, 04 May 2000 13:54:13 -0400
Marty Kraimer wrote:
> What causes the confusion is that old database access, which is what CA uses,
> only knows how to handle the maximum number of elements.
> The correct behavior is that  cvt_dbaddr sets no_elements = NELM, ie the size of
> the allocated array and get_array_info returns NORD, i.e. the current actual
> number of elements.
Does this explain why the value I sent no_elements to in get_array_info has
no effect on the number of elements actually returned to a CA client ?
Brian McAllister                 Application Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: CA and arrays Marty Kraimer
Prev: Extended talker/listener support in LanGPIB Version 2.4? Eric Norum
Next: Re: CA and arrays Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: aao-aai at JLAB for RF George Lahti
