1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with CA client in Linux
To: "EPICS collaboration" <[email protected]>
Date: Fri, 9 Jun 2000 09:34:50 +0200
Dear all,
We have been working with EPICS using Solaris and VxWorks for the
last three years, and now we would like to test EPICS (CA client) in Linux.
The Linux version that we have is Red Hat Linux release 6.1 with
Kernel 2.2.12-20 running on a Pentium PC.
We start the caRepeater by hand (as suggested in the README.Linux file),
and it works, but when we run a Channel Access test program then it crashes.
After an elementary debugging process (consisting in adding some "printf"s
before an after a function call) we have seen that the error appears
when "ca_task_initialize" is called. In particular, a "Segmentation fault"
happens when the function "ca_os_indepen_init" just returns.
I understand that this is not much information but any hint on this
problem will be very welcome.
Thanks in advance for your help.
                       Josep
_____________________________________________________
Dr. Josep A. Perlas
Lab. Llum Sincrotro - IFAE ------------  Tel: (+34 93)581.28.38
Edifici Cn, Campus UAB     ------------   Fax: (+34 93)581.32.13
E-08193 Bellaterra (Barcelona) SPAIN ---- email: [email protected]
Re: Problem with CA client in Linux D. Peter Siddons
Prev: Alarm for Analog Input Lars Ewell
Next: Re: Problem with CA client in Linux D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
