1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building base EPICS 3.13.2 under KAI C++ compiler
To: [email protected]
Date: Thu, 06 Jul 2000 14:57:52 -0500
I am building base EPICS (host) under KAI compiler KCC on Linux box
and build  was ok with several warnings.
Unfortunately, CA client does not work.
When I run ca_test (with excas running)  I got the following:
<d0lxbld4> ca_test janet
CAC: post_msg(): Corrupt cmd in UDP msg d00
../iocinf.c: bad UDP msg from d0lxbld4.fnal.gov:4526
err resp  was "User specified timeout on IO operation expired"
Not Found janet
At the same time with native gcc base EPICS build everything is ok on the
same machine (!)
and ca_test works ok and produces the right dump.
We are using :
Red Hat Linux Release 5.2.1
Kernel 2.2.12-20f1smp on an i686
KCC, v3_3f_1
gcc 2.7.2.3.f.1
Any hints where to look?
Vladimir
Re: Building base EPICS 3.13.2 under KAI C++ compiler Kay Kasemir
RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
Prev: RE: Problems with the CA lib under LynxOS with R3.13.2 Jeff Hill
Next: Re: Building base EPICS 3.13.2 under KAI C++ compiler Kay Kasemir
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
