Vladimir,
If your compiler does not define one of the following
( in base/src/ca/net_convert.h ) then you will need to
define an appropriate macro on the C compiler command
line using your version of the build system configuration
files. You will probably need "- D_M_IX86" or "-D_X86_".
Jeff
#if defined(VAX)
# define CA_FLOAT_MIT
# define CA_LITTLE_ENDIAN
#elif defined(_M_IX86) || defined(_X86_)
# define CA_FLOAT_IEEE
#elif (defined(__ALPHA) && defined(VMS) || defined(__alpha)) && defined(VMS)
#elif (defined(__ALPHA) && defined(UNIX) || defined(__alpha)) && defined(UNIX)
#else
# define CA_BIG_ENDIAN
#endif
> -----Original Message-----
> From: Vladimir Sirotenko [mailto:[email protected]]
> Sent: Thursday, July 06, 2000 1:58 PM
> To: [email protected]
> Subject: Building base EPICS 3.13.2 under KAI C++ compiler
> Hi,
> I am building base EPICS (host) under KAI compiler KCC on Linux box
> and build was ok with several warnings.
> Unfortunately, CA client does not work.
> When I run ca_test (with excas running) I got the following:
> <d0lxbld4> ca_test janet
> CAC: post_msg(): Corrupt cmd in UDP msg d00
> ../iocinf.c: bad UDP msg from d0lxbld4.fnal.gov:4526
> err resp was "User specified timeout on IO operation expired"
> Not Found janet
> At the same time with native gcc base EPICS build everything is ok on the
> same machine (!)
> and ca_test works ok and produces the right dump.
> We are using :
> Red Hat Linux Release 5.2.1
> Kernel 2.2.12-20f1smp on an i686
> KCC, v3_3f_1
> gcc 2.7.2.3.f.1
> Any hints where to look?
> Vladimir
- Re: Building base EPICS 3.13.2 under KAI C++ compiler Vladimir Sirotenko
- Building base EPICS 3.13.2 under KAI C++ compiler Vladimir Sirotenko
Re: Building base EPICS 3.13.2 under KAI C++ compiler Kay Kasemir
<2000>
2025
2026
<2000>
2025
2026
