Jeff, thanks very much. That was it !
Vladimir
----- Original Message -----
To: "Vladimir Sirotenko" <[email protected]>; <[email protected]>
Sent: Thursday, July 06, 2000 3:22 PM
Subject: RE: Building base EPICS 3.13.2 under KAI C++ compiler
> Vladimir,
> If your compiler does not define one of the following
> ( in base/src/ca/net_convert.h ) then you will need to
> define an appropriate macro on the C compiler command
> line using your version of the build system configuration
> files. You will probably need "- D_M_IX86" or "-D_X86_".
> Jeff
> #if defined(VAX)
> # define CA_FLOAT_MIT
> # define CA_LITTLE_ENDIAN
> #elif defined(_M_IX86) || defined(_X86_)
> # define CA_FLOAT_IEEE
> #elif (defined(__ALPHA) && defined(VMS) || defined(__alpha)) &&
defined(VMS)
> #elif (defined(__ALPHA) && defined(UNIX) || defined(__alpha)) &&
defined(UNIX)
> #else
> # define CA_BIG_ENDIAN
> #endif
> > -----Original Message-----
> > From: Vladimir Sirotenko [mailto:[email protected]]
> > Sent: Thursday, July 06, 2000 1:58 PM
> > To: [email protected]
> > Subject: Building base EPICS 3.13.2 under KAI C++ compiler
> > Hi,
> > I am building base EPICS (host) under KAI compiler KCC on Linux box
> > and build was ok with several warnings.
> > Unfortunately, CA client does not work.
> > When I run ca_test (with excas running) I got the following:
> > <d0lxbld4> ca_test janet
> > CAC: post_msg(): Corrupt cmd in UDP msg d00
> > ../iocinf.c: bad UDP msg from d0lxbld4.fnal.gov:4526
> > err resp was "User specified timeout on IO operation expired"
> > Not Found janet
> > At the same time with native gcc base EPICS build everything is ok on
the
> > same machine (!)
> > and ca_test works ok and produces the right dump.
> > We are using :
> > Red Hat Linux Release 5.2.1
> > Kernel 2.2.12-20f1smp on an i686
> > KCC, v3_3f_1
> > gcc 2.7.2.3.f.1
> > Any hints where to look?
> > Vladimir
- RE: Building base EPICS 3.13.2 under KAI C++ compiler Jeff Hill
memory leak - 7/10/00 cpu used is 74.7% normally 61-62% luchini
<2000>
2025
2026
<2000>
2025
2026
