Hello,
I'm having difficulty tracking down a slow memory leak in an EPICS ioc. This
ioc is a vme crate w/mv167 cpu (16MB memory) running VxWorks 5.3.1 (Tornado 1.0.1)
and EPICS R3.13.2. This memory leak occured when running EPICS R3.13.1.
I've increased the mbufs from the initial default setting of 40 to 500.
However, memory still seems to be creeping up slowly (maybe a bit slower)
about 4% per day. Upon reboot the initial memory usage is about 61%. I
booted the ioc on Friday at about 11:45am and today (Monday) at about 13:30 the
usage is 75%. The difference between this ioc and others
is that we have waveform records that are scanned once/second. We use DM2K to
display our waveforms but normally use dm for most of our EPICS displays.
I tried killing some EPICS displays (dm and DM2k) and this did not
seem to change the memory usage significantly (0.1% per display).
We are now using a gateway to filter EPICS channels since this ioc
has channels that other EPICS ioc's are interested in.
My next plan of attack, when operations
permits, is to kill/restart some sequences to see if this affects memory
usage. The reason to try this is that we have seen correlatation between
cpu usage (from a history archive on our legacy system) and Injection
into the pepii-ring. When injection occurs, one of the sequences performs
a bunch of data crunching of waveform data, and cpu usage goes up.
I've looked at the stacks from spawned tasks and they all seem fie.
Something that does seem suspicious is the number of collisions
from ifShow (3338748 collisions). Does anyone know what value
or percentage is reasonable?
I've attached some of the statisticts hoping that someone might
notice something and be able to give me a clue as to what I
might try next.
- Thanks,
Kristi Luchini
ic06pep00 -> tcpstatShow
TCP:
42842254 packets sent
41830724 data packets (902070680 bytes)
374 data packets (308976 bytes) retransmitted
1000422 ack-only packets (991693 delayed)
0 URG only packet
22 window probe packets
2102 window update packets
8610 control packets
24142873 packets received
22457256 acks (for 902069728 bytes)
3848 duplicate acks
0 ack for unsent data
2844650 packets (148805634 bytes) received in-sequence
8523 completely duplicate packets (97411 bytes)
0 packet with some dup. data (0 byte duped)
16 out-of-order packets (1656 bytes)
0 packet (0 byte) of data after window
0 window probe
124132 window update packets
0 packet received after close
0 discarded for bad checksum
0 discarded for bad header offset field
0 discarded because packet too short
8535 connection requests
110 connection accepts
117 connections established (including accepts)
8623 connections closed (including 4 drops)
8541 embryonic connections dropped
18423327 segments updated rtt (of 18432118 attempts)
111 retransmit timeouts
0 connection dropped by rexmit timeout
25 persist timeouts
2 keepalive timeouts
2 keepalive probes sent
0 connection dropped by keepalive
value = 36 = 0x24 = '$'
ic06pep00 -> mbufShow
type number
FREE : 354
DATA : 0
HEADER : 39
SOCKET : 0
PCB : 102
RTABLE : 3
HTABLE : 0
ATABLE : 0
SONAME : 0
ZOMBIE : 0
SOOPTS : 0
FTABLE : 0
RIGHTS : 0
IFADDR : 2
TOTAL : 500
number of mbufs: 500
number of clusters: 31
number of interface pages: 0
number of free clusters: 31
number of times failed to find space: 0
number of times waited for space: 0
number of times drained protocols for space: 0
value = 47 = 0x2f = '/'
bic06pep00 -> ifShow
ei (unit number 0):
Flags: (0x63) UP BROADCAST ARP RUNNING
Internet address: 172.19.55.62
Broadcast address: 172.19.55.255
Netmask 0xffff0000 Subnetmask 0xfffffc00
Ethernet address is 08:00:3e:24:9b:a9
Metric is 0
Maximum Transfer Unit size is 1500
27182998 packets received; 45104211 packets sent
1 input errors; 0 output errors
3338748 collisions
lo (unit number 0):
Flags: (0x69) UP LOOPBACK ARP RUNNING
Internet address: 127.0.0.1
Netmask 0xff000000 Subnetmask 0xff000000
Metric is 0
Maximum Transfer Unit size is 4096
801572 packets received; 801572 packets sent
0 input errors; 0 output errors
0 collisions
value = 18 = 0x12
bic06pep00 ->
bic06pep00 -> casr
Channel Access Server V4.8
Client Name="vxworks", Client Host="rfs12her03", V4.8, Channel Count=1
Client Name="babar", Client Host="cen-bip", V4.8, Channel Count=65
Client Name="cdepics", Client Host="opi00gtw02", V4.8, Channel Count=25
Client Name="vxworks", Client Host="rfs12her01", V4.8, Channel Count=1
Client Name="epicscp", Client Host="opi00gtw01", V4.8, Channel Count=19
Client Name="epicscp", Client Host="opi00gtw01", V4.8, Channel Count=46
Client Name="epicscp", Client Host="opi00gtw01", V4.8, Channel Count=5
Client Name="vxworks", Client Host="rfs04ler04", V4.8, Channel Count=1
Client Name="epicscp", Client Host="opi00gtw01", V4.8, Channel Count=35
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=31
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=4
Client Name="vxworks", Client Host="rfs04ler05", V4.8, Channel Count=1
Client Name="vxworks", Client Host="lfb04ler00", V4.7, Channel Count=1
Client Name="vxworks", Client Host="lfb04her00", V4.7, Channel Count=1
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=1
Client Name="vxworks", Client Host="rfs08her01", V4.8, Channel Count=1
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=33
Client Name="vxworks", Client Host="rfs08her03", V4.8, Channel Count=1
Client Name="babar", Client Host="cen-bip", V4.8, Channel Count=24
Client Name="vxworks", Client Host="rfs08her05", V4.8, Channel Count=1
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=5
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=7
Client Name="SLCSHR", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=2
Client Name="SLCSHR", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=204
Client Name="SLCSHR", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=9
Client Name="SLCSHR", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=29
Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=61
Client Name="cddev", Client Host="opi00gtw00", V4.8, Channel Count=2
Client Name="cddev", Client Host="opi00gtw00", V4.8, Channel Count=44
value = 0 = 0x0
bic06pep00 -> casr 1
TId=0XB141E8, Protocol=TCP, Socket FD=29
Secs since last send 4330.17, Secs since last receive 220418.64
Unprocessed request bytes=0, Undelivered response bytes=0
Client's DNS Host Name 172.19.55.61:4964 State=up
TId=0XAF93A8, Protocol=TCP, Socket FD=30
Secs since last send 0.05, Secs since last receive 1.52
Client's DNS Host Name cen-bip:4010 State=up
TId=0XAF5180, Protocol=TCP, Socket FD=31
Secs since last send 0.05, Secs since last receive 9.42
Client's DNS Host Name opi00gtw02:33733 State=up
TId=0XAF0E04, Protocol=TCP, Socket FD=32
Secs since last send 4330.18, Secs since last receive 220418.64
Client's DNS Host Name 172.19.55.60:3236 State=up
TId=0XAEC8D0, Protocol=TCP, Socket FD=33
Secs since last send 4672.62, Secs since last receive 220418.66
Client's DNS Host Name opi00gtw01:47683 State=up
TId=0XAE2158, Protocol=TCP, Socket FD=34
Secs since last send 0.10, Secs since last receive 18.42
Client's DNS Host Name opi00gtw01:47685 State=up
TId=0XADDA40, Protocol=TCP, Socket FD=35
Secs since last send 1.13, Secs since last receive 256438.61
Client's DNS Host Name opi00gtw01:47687 State=up
TId=0XA8EAD8, Protocol=TCP, Socket FD=37
Secs since last send 4478.43, Secs since last receive 35928.46
Client's DNS Host Name 172.19.55.68:3442 State=up
TId=0XA8A74C, Protocol=TCP, Socket FD=38
Secs since last send 0.93, Secs since last receive 256438.58
Client's DNS Host Name opi00gtw01:47686 State=up
TId=0XA860C0, Protocol=TCP, Socket FD=39
Secs since last send 0.10, Secs since last receive 0.40
Unprocessed request bytes=5992, Undelivered response bytes=0
Client's DNS Host Name opi00gtw01:47688 State=up
TId=0XA81D30, Protocol=TCP, Socket FD=40
Secs since last send 0.10, Secs since last receive 6.35
Unprocessed request bytes=2976, Undelivered response bytes=0
Client's DNS Host Name opi00gtw01:47689 State=up
TId=0XA63118, Protocol=TCP, Socket FD=13
Secs since last send 0.08, Secs since last receive 38.38
Client's DNS Host Name opi00gtw00:56930 State=up
TId=0XA6047C, Protocol=TCP, Socket FD=42
Secs since last send 0.10, Secs since last receive 19.60
Client's DNS Host Name opi00gtw01:47690 State=up
TId=0XA5C254, Protocol=TCP, Socket FD=43
Secs since last send 0.12, Secs since last receive 21799.22
Client's DNS Host Name opi00gtw00:56932 State=up
TId=0XA51E44, Protocol=TCP, Socket FD=44
Secs since last send 4478.47, Secs since last receive 220418.67
Client's DNS Host Name 172.19.55.69:1760 State=up
TId=0XA0D724, Protocol=TCP, Socket FD=45
Secs since last send 1.60, Secs since last receive 1.60
Client's DNS Host Name 172.19.55.50:1908 State=up
TId=0XA094FC, Protocol=TCP, Socket FD=46
Secs since last send 0.12, Secs since last receive 55.93
Client's DNS Host Name opi00gtw01:47691 State=up
TId=0XA052D4, Protocol=TCP, Socket FD=47
Secs since last send 0.12, Secs since last receive 0.15
Client's DNS Host Name opi00gtw01:47692 State=up
TId=0XA010AC, Protocol=TCP, Socket FD=48
Secs since last send 1.23, Secs since last receive 1.23
Client's DNS Host Name 172.19.55.55:2238 State=up
TId=0X9FCE84, Protocol=TCP, Socket FD=49
Secs since last send 0.13, Secs since last receive 2159.73
Client's DNS Host Name opi00gtw00:56933 State=up
TId=0X9F8C5C, Protocol=TCP, Socket FD=50
Secs since last send 1962.45, Secs since last receive 1962.45
Client's DNS Host Name 172.19.55.64:4767 State=up
TId=0X9F4904, Protocol=TCP, Socket FD=51
Secs since last send 0.13, Secs since last receive 27.43
Client's DNS Host Name opi00gtw00:56934 State=up
TId=0X9EA3C4, Protocol=TCP, Socket FD=52
Secs since last send 847.77, Secs since last receive 847.77
Client's DNS Host Name 172.19.55.65:1191 State=up
TId=0X9A59B8, Protocol=TCP, Socket FD=53
Secs since last send 0.15, Secs since last receive 256437.86
Client's DNS Host Name cen-bip:4011 State=up
TId=0X9A1510, Protocol=TCP, Socket FD=54
Secs since last send 4330.25, Secs since last receive 14187.92
Client's DNS Host Name 172.19.55.66:3246 State=up
TId=0X99D004, Protocol=TCP, Socket FD=55
Secs since last send 1.00, Secs since last receive 256437.75
Client's DNS Host Name opi00gtw01:47693 State=up
TId=0X998B28, Protocol=TCP, Socket FD=56
Secs since last send 0.13, Secs since last receive 57.18
Client's DNS Host Name opi00gtw00:56937 State=up
TId=0X994628, Protocol=TCP, Socket FD=57
Secs since last send 0.17, Secs since last receive 19.22
Client's DNS Host Name opi00gtw00:56938 State=up
TId=0X98E03C, Protocol=TCP, Socket FD=59
Secs since last send 28.82, Secs since last receive 28.82
Client's DNS Host Name mcc:1923 State=up
TId=0X9487FC, Protocol=TCP, Socket FD=58
Secs since last send 82.70, Secs since last receive 82.72
Client's DNS Host Name mcc:1924 State=up
TId=0X939504, Protocol=TCP, Socket FD=63
Secs since last send 2.98, Secs since last receive 2.98
Client's DNS Host Name mcc:1925 State=up
TId=0X75AD28, Protocol=TCP, Socket FD=11
Secs since last send 0.20, Secs since last receive 0.12
Client's DNS Host Name mcc:1926 State=up
TId=0X71A57C, Protocol=TCP, Socket FD=14
Secs since last send 0.17, Secs since last receive 11129.47
Client's DNS Host Name opi00gtw00:57526 State=up
TId=0X548E88, Protocol=TCP, Socket FD=36
Secs since last send 2772.93, Secs since last receive 2772.93
Client's DNS Host Name opi00gtw00:57619 State=up
TId=0X540CF0, Protocol=TCP, Socket FD=41
Secs since last send 0.18, Secs since last receive 0.18
Client's DNS Host Name opi00gtw00:57626 State=up
NAME ENTRY TID PRI total % (ticks) delta % (ticks)
tExcTask _excTask fdd900 0 0% ( 0) 0% ( 0)
tLogTask _logTask fdafec 0 0% ( 0) 0% ( 0)
tShell _shell f857b8 1 0% ( 1) 0% ( 0)
tRlogind _rlogind f92c08 2 0% ( 0) 0% ( 0)
tTelnetd _telnetd f90d50 2 0% ( 0) 0% ( 0)
tRlogOutTask _rlogOutTa 53cac8 2 4% ( 60) 4% ( 26)
tRlogInTask _rlogInTas 53b59c 2 0% ( 0) 0% ( 0)
tWdbTask f87180 3 0% ( 0) 0% ( 0)
tSpyTask _spyComTas 539708 5 14% ( 188) 15% ( 95)
tAioIoTask1 _aioIoTask fce238 50 0% ( 0) 0% ( 0)
tAioIoTask0 _aioIoTask fc7094 50 0% ( 0) 0% ( 0)
tNetTask _netTask fae390 50 3% ( 42) 3% ( 22)
tAioWait _aioWaitTa fd53dc 51 0% ( 0) 0% ( 0)
tFtpdTask _ftpdTask f8e2f8 55 0% ( 0) 0% ( 0)
tBit3Scan c72f88 65 0% ( 1) 0% ( 1)
scan3 b85758 66 0% ( 0) 0% ( 0)
tGpibQ0 _ipGpibSca c7222c 67 5% ( 75) 5% ( 33)
scan6 b88414 67 1% ( 20) 3% ( 20)
scan12 b8b0d0 68 0% ( 0) 0% ( 0)
scan30 b8dd8c 69 0% ( 10) 1% ( 9)
ts_Casync c5d254 70 0% ( 0) 0% ( 0)
scan60 b90a48 70 0% ( 12) 0% ( 6)
cbHigh _callbackT c788c0 71 0% ( 0) 0% ( 0)
scan120 b93704 71 0% ( 7) 0% ( 3)
scan300 b963c0 72 0% ( 2) 0% ( 1)
scan600 b9907c 73 0% ( 1) 0% ( 1)
scan1800 b9bd38 74 0% ( 0) 0% ( 0)
cbMedium _callbackT c7d4a8 75 0% ( 0) 0% ( 0)
scan3600 b9e9f4 75 0% ( 0) 0% ( 0)
scan7200 ba16b0 76 0% ( 0) 0% ( 0)
scan18000 ba436c 77 0% ( 0) 0% ( 0)
scan216000 ba7028 78 0% ( 0) 0% ( 0)
cbLow _callbackT ca12d0 85 0% ( 3) 0% ( 3)
scanOnce ba9e2c 85 0% ( 0) 0% ( 0)
EV dbCaLink _event_tas c6157c 87 0% ( 0) 0% ( 0)
dbCaLink _dbCaTask c75c24 88 0% ( 0) 0% ( 0)
RD dbCaLink _cac_recv_ b77db8 89 1% ( 14) 0% ( 5)
EV tSaveRest _event_tas a6f274 95 0% ( 3) 0% ( 2)
tSaveRestore a7cd58 96 2% ( 31) 2% ( 18)
RD tSaveRest _cac_recv_ 96ef18 97 1% ( 13) 0% ( 6)
EV seqAux _event_tas 95a1ac 98 0% ( 4) 0% ( 1)
seqAux _seqAuxTas 969404 99 0% ( 3) 0% ( 1)
tPortmapd _portmapd f8f824 100 0% ( 0) 0% ( 0)
tCmlogDaemon _cmlogClie e6e648 100 0% ( 0) 0% ( 0)
tCmlogLogMsg _cmlogVxLo e69684 100 0% ( 0) 0% ( 0)
Bic_Babar _sequencer 9581b8 100 0% ( 0) 0% ( 0)
Bic_Lum _sequencer 94cc38 100 1% ( 16) 1% ( 8)
Bic_Proc_HER _sequencer 8f28bc 100 1% ( 19) 1% ( 8)
Bic_Stat_HER _sequencer 8e7ab0 100 0% ( 0) 0% ( 0)
HER_Bic_Bunc _sequencer 8aefb0 100 12% ( 158) 12% ( 78)
HER_Bic_Curr _sequencer 89b508 100 0% ( 8) 0% ( 4)
HER_Bic_Deca _sequencer 882d20 100 0% ( 1) 0% ( 0)
HER_Bic_Cals _sequencer 87f498 100 0% ( 6) 0% ( 4)
HER_Bic_Scro _sequencer 879fdc 100 0% ( 0) 0% ( 0)
Bic_Proc_LER _sequencer 80f554 100 2% ( 27) 1% ( 12)
Bic_Stat_LER _sequencer 806548 100 0% ( 0) 0% ( 0)
LER_Bic_Bunc _sequencer 7db6a4 100 12% ( 164) 12% ( 79)
LER_Bic_Curr _sequencer 7c9dbc 100 0% ( 7) 0% ( 4)
LER_Bic_Deca _sequencer 7c302c 100 0% ( 0) 0% ( 0)
LER_Bic_Cals _sequencer 7bd42c 100 0% ( 5) 0% ( 1)
LER_Bic_Scro _sequencer 7b9a24 100 0% ( 0) 0% ( 0)
CA client _camsgtask b141e8 180 0% ( 0) 0% ( 0)
CA client _camsgtask af93a8 180 0% ( 1) 0% ( 0)
CA client _camsgtask af5180 180 0% ( 0) 0% ( 0)
CA client _camsgtask af0e04 180 0% ( 0) 0% ( 0)
CA client _camsgtask aec8d0 180 0% ( 0) 0% ( 0)
CA client _camsgtask ae2158 180 0% ( 0) 0% ( 0)
CA client _camsgtask adda40 180 0% ( 0) 0% ( 0)
CA client _camsgtask a8ead8 180 0% ( 0) 0% ( 0)
CA client _camsgtask a8a74c 180 0% ( 0) 0% ( 0)
CA client _camsgtask a860c0 180 0% ( 0) 0% ( 0)
CA client _camsgtask a81d30 180 0% ( 0) 0% ( 0)
CA client _camsgtask a63118 180 0% ( 0) 0% ( 0)
CA client _camsgtask a6047c 180 0% ( 0) 0% ( 0)
CA client _camsgtask a5c254 180 0% ( 0) 0% ( 0)
CA client _camsgtask a51e44 180 0% ( 0) 0% ( 0)
CA client _camsgtask a0d724 180 0% ( 1) 0% ( 1)
CA client _camsgtask a094fc 180 0% ( 0) 0% ( 0)
CA client _camsgtask a052d4 180 0% ( 0) 0% ( 0)
CA client _camsgtask a010ac 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9fce84 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9f8c5c 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9f4904 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9ea3c4 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9a59b8 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9a1510 180 0% ( 0) 0% ( 0)
CA client _camsgtask 99d004 180 0% ( 0) 0% ( 0)
CA client _camsgtask 998b28 180 0% ( 0) 0% ( 0)
CA client _camsgtask 994628 180 0% ( 0) 0% ( 0)
CA client _camsgtask 98e03c 180 0% ( 0) 0% ( 0)
CA client _camsgtask 9487fc 180 0% ( 0) 0% ( 0)
CA client _camsgtask 939504 180 0% ( 0) 0% ( 0)
CA client _camsgtask 75ad28 180 0% ( 2) 0% ( 1)
CA client _camsgtask 71a57c 180 0% ( 0) 0% ( 0)
CA client _camsgtask 548e88 180 0% ( 0) 0% ( 0)
CA client _camsgtask 540cf0 180 0% ( 0) 0% ( 0)
errlog f726f0 181 0% ( 0) 0% ( 0)
CA repeater c68cf0 181 0% ( 3) 0% ( 2)
CA TCP _req_serve b829a0 181 0% ( 0) 0% ( 0)
CA event _event_tas b1154c 181 0% ( 0) 0% ( 0)
CA event _event_tas af670c 181 2% ( 26) 2% ( 14)
CA event _event_tas af24c0 181 0% ( 0) 0% ( 0)
CA event _event_tas aee028 181 0% ( 0) 0% ( 0)
CA event _event_tas ae9ad4 181 0% ( 0) 0% ( 0)
CA event _event_tas adefcc 181 0% ( 3) 0% ( 2)
CA event _event_tas adac44 181 0% ( 0) 0% ( 0)
CA event _event_tas a8bcfc 181 0% ( 0) 0% ( 0)
CA event _event_tas a87970 181 0% ( 0) 0% ( 0)
CA event _event_tas a832d0 181 0% ( 9) 0% ( 5)
CA event _event_tas a7ef54 181 0% ( 3) 0% ( 2)
CA event _event_tas f6b238 181 0% ( 4) 0% ( 0)
CA event _event_tas a5d7e0 181 0% ( 4) 0% ( 3)
CA event _event_tas a533d0 181 0% ( 0) 0% ( 0)
CA event _event_tas a0ecb0 181 0% ( 0) 0% ( 0)
CA event _event_tas a0aa88 181 0% ( 0) 0% ( 0)
CA event _event_tas a06860 181 0% ( 6) 0% ( 4)
CA event _event_tas a02638 181 0% ( 9) 0% ( 3)
CA event _event_tas 9fe410 181 0% ( 0) 0% ( 0)
CA event _event_tas 9fa1e8 181 0% ( 0) 0% ( 0)
CA event _event_tas 9f5fc0 181 0% ( 0) 0% ( 0)
CA event _event_tas 9eba80 181 0% ( 2) 0% ( 1)
CA event _event_tas 9a70f0 181 0% ( 0) 0% ( 0)
CA event _event_tas 9a2aac 181 0% ( 2) 0% ( 1)
CA event _event_tas 99e724 181 0% ( 0) 0% ( 0)
CA event _event_tas 99a228 181 0% ( 0) 0% ( 0)
CA event _event_tas 995d2c 181 0% ( 2) 0% ( 1)
CA event _event_tas 99183c 181 0% ( 3) 0% ( 2)
CA event _event_tas 98b260 181 0% ( 0) 0% ( 0)
CA event _event_tas 945b60 181 0% ( 0) 0% ( 0)
CA event _event_tas 8f6370 181 0% ( 0) 0% ( 0)
CA event _event_tas a7a018 181 0% ( 0) 0% ( 0)
CA event _event_tas 5e674c 181 0% ( 3) 0% ( 1)
CA event _event_tas 5461ec 181 0% ( 0) 0% ( 0)
CA event _event_tas 53e054 181 0% ( 1) 0% ( 1)
CA UDP _cast_serv b81414 182 0% ( 4) 0% ( 2)
CA online _rsrv_onli b69e30 183 0% ( 0) 0% ( 0)
tCmlogD_c e606b4 190 0% ( 0) 0% ( 0)
tCmlogL_c e66dd0 199 0% ( 0) 0% ( 0)
logRestart e6f7ec 200 0% ( 0) 0% ( 0)
taskwd ce1408 200 0% ( 0) 0% ( 0)
cpuUsageTask c5fff0 255 17% ( 226) 16% ( 107)
KERNEL 3% ( 49) 3% ( 25)
INTERRUPT 0% ( 7) 0% ( 3)
IDLE 0% ( 0) 0% ( 0)
TOTAL 81% ( 1271) 81% ( 631)
spyStop
value = 0 = 0x0
bic06pep00 ->
bic06pep00 -> checkStack
NAME ENTRY TID SIZE CUR HIGH MARGIN
tExcTask _excTask fdd900 7988 164 808 7180
tLogTask _logTask fdafec 4988 168 936 4052
tShell _shell f857b8 9000 868 4156 4844
tRlogind _rlogind f92c08 4988 836 1468 3520
tTelnetd _telnetd f90d50 4988 236 468 4520
tRlogOutTask _rlogOutTask 53cac8 4984 352 916 4068
tRlogInTask _rlogInTask 539708 4988 392 604 4384
tWdbTask 0x000004a56e f87180 3760 356 612 3148
tAioIoTask1 _aioIoTask fce238 28660 88 164 28496
tAioIoTask0 _aioIoTask fc7094 28660 88 164 28496
tNetTask _netTask fae390 9988 104 916 9072
tAioWait _aioWaitTask fd53dc 28660 272 524 28136
tFtpdTask _ftpdTask f8e2f8 11988 228 444 11544
tBit3Scan 0x0000e28f3a c72f88 2664 80 220 2444
scan3 0x0000eea9aa b85758 10668 76 216 10452
tGpibQ0 _ipGpibScan c7222c 4668 80 1040 3628
scan6 0x0000eea9aa b88414 10668 76 996 9672
scan12 0x0000eea9aa b8b0d0 10668 76 204 10464
scan30 0x0000eea9aa b8dd8c 10668 76 1376 9292
ts_Casync 0x0000ee8ace c5d254 4664 768 2100 2564
scan60 0x0000eea9aa b90a48 10668 76 1628 9040
cbHigh _callbackTas c788c0 10668 72 148 10520
scan120 0x0000eea9aa b93704 10668 76 1240 9428
scan300 0x0000eea9aa b963c0 10668 76 1140 9528
scan600 0x0000eea9aa b9907c 10668 76 1228 9440
scan1800 0x0000eea9aa b9bd38 10664 76 180 10484
cbMedium _callbackTas c7d4a8 10664 72 148 10516
scan3600 0x0000eea9aa b9e9f4 10664 76 160 10504
scan7200 0x0000eea9aa ba16b0 10664 76 152 10512
scan18000 0x0000eea9aa ba436c 10664 76 160 10504
scan216000 0x0000eea9aa ba7028 10664 76 152 10512
cbLow _callbackTas ca12d0 10668 72 1224 9444
scanOnce 0x0000eea7fe ba9e2c 10664 64 484 10180
EV dbCaLink _event_task c6157c 4760 72 268 4492
dbCaLink _dbCaTask c75c24 10664 84 1372 9292
RD dbCaLink _cac_recv_ta b77db8 3760 320 1248 2512
EV tSaveRest _event_task a6f274 4756 72 4104 652
tSaveRestore 0x0000f626b4 a7cd58 9660 200 4576 5084
RD tSaveRest _cac_recv_ta 96ef18 3756 320 852 2904
EV seqAux _event_task 95a1ac 4760 72 3296 1464
seqAux _seqAuxTask 969404 1668 192 668 1000
tPortmapd _portmapd f8f824 4988 328 584 4404
tCmlogDaemon _cmlogClient e6e648 19984 168 872 19112
tCmlogLogMsg _cmlogVxLogM e69684 9984 168 872 9112
Bic_Babar _sequencer 9581b8 9664 156 3376 6288
Bic_Lum _sequencer 94cc38 9668 232 3560 6108
Bic_Proc_HER _sequencer 8f28bc 9660 188 3560 6100
Bic_Stat_HER _sequencer 8e7ab0 19660 156 3396 16264
HER_Bic_Bunc _sequencer 8aefb0 9660 208 3604 6056
HER_Bic_Curr _sequencer 89b508 9660 156 3552 6108
HER_Bic_Deca _sequencer 882d20 9656 192 3372 6284
HER_Bic_Cals _sequencer 87f498 9656 228 3524 6132
HER_Bic_Scro _sequencer 879fdc 9660 156 3396 6264
Bic_Proc_LER _sequencer 80f554 9660 188 3552 6108
Bic_Stat_LER _sequencer 806548 19660 156 3408 16252
LER_Bic_Bunc _sequencer 7db6a4 9660 240 3604 6056
LER_Bic_Curr _sequencer 7c9dbc 9660 156 3552 6108
LER_Bic_Deca _sequencer 7c302c 9656 192 3372 6284
LER_Bic_Cals _sequencer 7bd42c 9656 228 3516 6140
LER_Bic_Scro _sequencer 7b9a24 9660 156 3396 6264
CA client _camsgtask b141e8 10664 424 992 9672
CA client _camsgtask af93a8 10664 424 1000 9664
CA client _camsgtask af5180 10664 424 3048 7616
CA client _camsgtask af0e04 10664 424 992 9672
CA client _camsgtask aec8d0 10664 424 3076 7588
CA client _camsgtask ae2158 10664 424 3040 7624
CA client _camsgtask adda40 10664 424 992 9672
CA client _camsgtask a8ead8 10664 424 992 9672
CA client _camsgtask a8a74c 10664 424 992 9672
CA client _camsgtask a860c0 10664 424 3068 7596
CA client _camsgtask a81d30 10664 424 3040 7624
CA client _camsgtask a63118 10664 424 3076 7588
CA client _camsgtask a6047c 10664 424 3040 7624
CA client _camsgtask a5c254 10664 424 992 9672
CA client _camsgtask a51e44 10664 424 992 9672
CA client _camsgtask a0d724 10664 424 2984 7680
CA client _camsgtask a094fc 10664 424 3040 7624
CA client _camsgtask a052d4 10664 424 3040 7624
CA client _camsgtask a010ac 10664 424 3000 7664
CA client _camsgtask 9fce84 10664 424 992 9672
CA client _camsgtask 9f8c5c 10664 424 992 9672
CA client _camsgtask 9f4904 10664 424 3104 7560
CA client _camsgtask 9ea3c4 10664 424 992 9672
CA client _camsgtask 9a59b8 10664 424 992 9672
CA client _camsgtask 9a1510 10664 424 992 9672
CA client _camsgtask 99d004 10664 424 992 9672
CA client _camsgtask 998b28 10664 424 992 9672
CA client _camsgtask 994628 10664 424 992 9672
CA client _camsgtask 98e03c 10664 424 1040 9624
CA client _camsgtask 9487fc 10664 424 3004 7660
CA client _camsgtask 939504 10664 424 3048 7616
CA client _camsgtask 75ad28 10664 424 3040 7624
CA client _camsgtask 71a57c 10664 424 3100 7564
CA client _camsgtask 548e88 10664 424 2936 7728
CA client _camsgtask 540cf0 10664 424 3308 7356
errlog 0x0000f05282 f726f0 3668 80 1128 2540
CA repeater 0x0000f16d6c c68cf0 4760 364 1212 3548
CA TCP _req_server b829a0 4764 196 596 4168
CA event _event_task b1154c 4760 72 2716 2044
CA event _event_task af670c 4760 72 2856 1904
CA event _event_task af24c0 4760 72 2848 1912
CA event _event_task aee028 4760 72 2720 2040
CA event _event_task ae9ad4 4760 72 2724 2036
CA event _event_task adefcc 4760 72 2860 1900
CA event _event_task adac44 4760 72 2824 1936
CA event _event_task a8bcfc 4760 72 2720 2040
CA event _event_task a87970 4760 72 2848 1912
CA event _event_task a832d0 4760 72 2884 1876
CA event _event_task a7ef54 4760 72 2860 1900
CA event _event_task f6b238 4760 72 2856 1904
CA event _event_task a5d7e0 4760 72 2860 1900
CA event _event_task a533d0 4760 72 2836 1924
CA event _event_task a0ecb0 4760 72 2716 2044
CA event _event_task a0aa88 4760 72 268 4492
CA event _event_task a06860 4760 72 2860 1900
CA event _event_task a02638 4760 72 2888 1872
CA event _event_task 9fe410 4760 72 268 4492
CA event _event_task 9fa1e8 4760 72 2848 1912
CA event _event_task 9f5fc0 4760 72 2732 2028
CA event _event_task 9eba80 4760 72 2868 1892
CA event _event_task 9a70f0 4760 72 2720 2040
CA event _event_task 9a2aac 4760 72 2996 1764
CA event _event_task 99e724 4760 72 2716 2044
CA event _event_task 99a228 4760 72 2832 1928
CA event _event_task 995d2c 4760 72 2860 1900
CA event _event_task 99183c 4760 72 2860 1900
CA event _event_task 98b260 4760 72 2780 1980
CA event _event_task 945b60 4760 72 268 4492
CA event _event_task 8f6370 4760 72 280 4480
CA event _event_task a7a018 4760 72 956 3804
CA event _event_task 5e674c 4760 72 2848 1912
CA event _event_task 5461ec 4760 72 2724 2036
CA event _event_task 53e054 4760 72 2836 1924
CA UDP _cast_server b81414 4764 432 1064 3700
CA online _rsrv_online b69e30 2712 140 1204 1508
tCmlogD_c 0x0000e7f3b4 e606b4 18996 1108 2764 16232
tCmlogL_c 0x0000f50016 e66dd0 9664 396 2220 7444
logRestart 0x0000f0816e e6f7ec 3760 72 1268 2492
taskwd 0x0000ef26a4 ce1408 1668 184 336 1332
cpuUsageTask 0x0000ec90e2 c5fff0 2660 356 532 2128
INTERRUPT
Re: Building base EPICS 3.13.2 under KAI C++ compiler Vladimir Sirotenko
Performance of portable CA server ? jennings
<2000>
2025
2026
RE: memory leak - 7/10/00 cpu used is 74.7% normally 61-62% Allison, Stephanie
<2000>
2025
2026
