1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca error
To: <[email protected]>
Date: Fri, 22 Sep 2000 08:01:28 -1000 (HST)
Hi GongFa,
The message indicates too many open files. Why would that happen is
not clear, we don't use iocLogClient on our ioc (!)
Try login on your console and type 'iosFdShow'.
It depend on what you'd expect, but you always could increase the
default value (50) by recompiling VxWorks, there's an entry
NUM_FILES in your config.h that set the maximum.
hope that helps,
Matthieu
Matthieu Bec              Gemini Observatory
Tel: +1 808 9742557       670 N. A'ohoku Place
Fax: +1 808 9359235       Hilo, Hawaii 96720, USA
Re: ca error Dale L. Brewe
ca error GongFa Liu
Prev: ca error GongFa Liu
Next: Re: ca error Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
