1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca error
To: <[email protected]>
Date: Fri, 22 Sep 2000 15:47:57 -0500
We had a similar problem awhile back when we were using FTP for network
file access - I forget the details, but files weren't getting closed
between writes, and file descripters were getting used up. We haven't had a
problem since we changed to NFS.
Dale
>The message indicates too many open files. Why would that happen is
>not clear, we don't use iocLogClient on our ioc (!)
>Try login on your console and type 'iosFdShow'.
>It depend on what you'd expect, but you always could increase the
>default value (50) by recompiling VxWorks, there's an entry
>NUM_FILES in your config.h that set the maximum.
  Dale L. Brewe     PNC-CAT/U. of Washington
  ph: 630 252 0582         fax: 630 252 0580
  Mail:
  Argonne National Laboratory/APS
  Bldg 435E sector 20
  9700 S. Cass Ave.
  Argonne, IL 60439
Re: ca error Matthieu Bec
Prev: Re: ca error Matthieu Bec
Next: scan tasks and monitors??? Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Another ca error GongFa Liu
