1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm icon
To: "Paul Sichta" <[email protected]>
Cc: Ken Evans <[email protected]>, <[email protected]>
Date: Wed, 27 Sep 2000 18:25:27 -0400
> We use x-terminals (Open-Windows now but CDE soon) to display medm_2.3.4a
> displays.  When the operator minimizes the display to an icon,  the icon
> label is the .adl file's name,  left-justified,  including the full
> pathname.  So ,  the icon labels are the same for all medm displays, showing
> the very top few directories in the path.
> Is there a way to right-justify the icon label (xset?) and/or a way to
> specify the icon label's text (medm command line?)  ?
This happens when you open a .adl file from the "Open" dialog.  The
"selection" text includes the full path to the file.  If you clear it, and
type in the name of the file you want to open, or select one from the list
and then delete the leading path elements, the icon name will be just the
file name.  Note that this only works if the file you want to open is in
the directory which was the current working directory when MEDM was run.
Ken:
The window title is set using medmSetDisplayTitle(), which strips off the
leading path, while the icon name is just set to displayInfo->dlFile->name,
which includes the full path.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: medm icon Pete R. Jemian
medm icon Paul Sichta
Prev: Re: medm icon Ken Evans
Next: compiling seq-1.9.5 with WIN32 Benjamin Sailer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: medm icon Paul Sichta
Next: Re: medm icon Pete R. Jemian
