1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm icon
To: Tech-Talk <[email protected]>
Cc: "Brian McAllister" <[email protected]>
Date: Thu, 28 Sep 2000 10:31:29 -0500
You think this is the only way to get a full path name in the icon title? Look again.
We open "related displays" exclusively and get the full path name
when the screen is iconified.  These long icon names have
been observed for more than 5 years of MEDM versions.
Note that MEDM is the _only_ X window application I use
that seems to have the full path names in the iconified state..
Also note that this behavior is observed with both X-Win32
(http://www.starnet.com) and eXceed (www.hummingbird.com)
X window servers.
Pete Jemian
   UNICAT
At 06:25 PM 27-09-00 -0400, you wrote:
> We use x-terminals (Open-Windows now but CDE soon) to display medm_2.3.4a
> displays. When the operator minimizes the display to an icon, the icon
> label is the .adl file's name, left-justified, including the full
> pathname. So , the icon labels are the same for all medm displays, showing
> the very top few directories in the path.
> Is there a way to right-justify the icon label (xset?) and/or a way to
> specify the icon label's text (medm command line?) ?
This happens when you open a .adl file from the "Open" dialog.  The
"selection" text includes the full path to the file.  If you clear it, and
type in the name of the file you want to open, or select one from the list
and then delete the leading path elements, the icon name will be just the
file name.  Note that this only works if the file you want to open is in
the directory which was the current working directory when MEDM was run.
Ken:
The window title is set using medmSetDisplayTitle(), which strips off the
leading path, while the icon name is just set to displayInfo->dlFile->name,
which includes the full path.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: medm icon Brian McAllister
medm icon Paul Sichta
Prev: RE: compiling seq-1.9.5 with WIN32 Jeff Hill
Next: Re: medm icon Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: medm icon Brian McAllister
