1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PowerPC Users: struct timespec problems
To: EPICS tech-talk <[email protected]>
Date: Mon, 02 Oct 2000 14:26:25 -0500
Note to all sites using Power PCs, all EPICS versions.
There is a problem in ccppc when it generates code that copies a  struct
timespec, which happens quite a lot in base/src/db/drvTS.c.  The compiler
uses a floating-point register to assign values of this 8-byte structure
type, which is unfortunate if the resulting code is called from an
Interrupt Service Routine without having saved the floating point
registers (no floating-point source numbers are involved, so fppSave() and
fppRestore() do not seem necessary).  The same effect could potentially
occur with any 8-byte structure, but note that the problem only happens
when you have code like  sp = sp2  where these are both 8-byte structs
(not pointers to structs).
We have been wrestling with this problem at APS on our first PPC system to
incorporate an event receiver card (which provides accurate timestamps to
the card).  Systems that just use the normal EPICS soft time do not seem
to suffer from it.  The compilers from Tornado 1.0.1 and 2.0 both exhibit
the fault.
I have just checked WindSurf and found that this has already been reported
as SPR#28373 and a workaround is discussed in that report: add the
compiler flag -mstrict-align which tells ccppc not to assume that such a
struct is 8-byte aligned, so it reverts to using standard register
load/save instructions.  This flag will be added to the EPICS file
base/config/CONFIG.Vx.ppc604 and equivalents for all future EPICS
releases, but sites using the PPC are advised to make this change to their
existing installations to avoid having it bite you unexpectedly.  I would
also recommend at least recompiling drvTS.c and rebuilding the EPICS
libraries afterwards.
- Andrew
Every great idea appears crazy to start with.
Prev: Re: intConnect vs ipmIntConnect vs devConnectInterrupt Andrew Johnson
Next: PowerPC again: Use of floating point in vxWorks shell Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: intConnect vs ipmIntConnect vs devConnectInterrupt Bernd Schoeneburg
