1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Tornado/2.0 error message
To: "Pete R. Jemian" <[email protected]>, "Tech-Talk" <[email protected]>
Date: Mon, 23 Oct 2000 15:27:53 -0600
> >2000-10-23,12:18:11: interrupt: callbackRequest ring buffer full
This indicates that some interrupt service routine
is calling the EPICS routine callbackRequest() to add callback requests
to the callback queue at a rate that is faster than the callback thread
can dispatch the requested callbacks. This might occur if an EPICS
driver was calling scanIORequest() from interrupt level very frequently
or it might occur because some other high priority thread is saturating
the CPU and preventing the callback thread from running.
> >2000-10-23,09:09:45: 0x78dd64 (tNetTask): arptnew failed on a436d813
> >2000-10-23,09:15:45: 0x78dd64 (tNetTask): arptnew failed on a436d813
> >2000-10-23,09:23:45: 0x78dd64 (tNetTask): arptnew failed on a436d813
> >2000-10-23,09:29:45: 0x78dd64 (tNetTask): arptnew failed on a436d813
> >2000-10-23,09:35:45: 0x78dd64 (tNetTask): arptnew failed on a436d813
> >2000-10-23,09:43:45: 0x78dd64 (tNetTask): arptnew failed on se
Perhaps these errors are resulting from attempts by arp to build an
Ethernet address <=> IP address association, but there is already
an inconsistent entry in its tables. I would type "arpShow" to see
if there are configuration problems (possibly related to a back plane
network).
Jeff
Re: Tornado/2.0 error message Andrew Johnson
Tornado/2.0 error message Pete R. Jemian
Prev: Tornado/2.0 error message Pete R. Jemian
Next: Re: Tornado/2.0 error message Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
