At 09:12 AM 10/27/00 +0800, chengwx wrote:
>Hello everyone, I have make the epics base and medm. and make the epics
>application on my Redhat6.2.
>But when download the vxWorks, it comes the errors like this :
>[VxWorks Boot]: @
>Loading... 413736 + 43300 + 35280 /* the ioc stopped
>here, no moving at all*/
I had a similar problem when loading from RedHat 6.2.
The problem was in wuftpd.
In fact we use almost the same ftpd on solaris and there the problem
didn't appear, so I don't understand it fully, but these were symptons
and the solution:
Sympton:
IOC hangs after loading.
netstat -a confirmed that the ftp connection was stuck:
tcp 0 0 bogart.ta53.la:ftp-data snsioc4.ta53.lanl.:1025 FIN_WAIT2
tcp 6 0 bogart.ta53.lanl.go:ftp snsioc4.ta53.lanl.:1024 ESTABLISHED
(bogart is the host, snsioc4 is the ioc)
In fact it continues after about 15min,
the 15min(!) delay corresponds to the ftpd timeout.
One quick solution was
killall in.ftpd
-> the remaining startup-file and commands like "ld <iocCore" in there
load just fine.
I assumed that the "verbose" wu-ftpd was the cause:
It displays "welcome" and statistic messages in addition to
the bare ftp protocol, but a recompilation without that extra text
didn't help.
The solution that I use was in <Tornado2>/target/config/all/bootConfig.c:
if (bootRsh == FALSE)
/* Empty the Data Socket before close. PC FTP server hangs otherwise */
while ((read (fd, command, sizeof (command))) > 0);
if (bootFtp)
(void) ftpCommand (errFd, "QUIT",0,0,0,0,0,0);
close (fd);
close (errFd);
return (OK);
Commenting out the while (read) and ftpCommand ("QUIT") solved
the problem.
-Kay
- Re: Download vxWorks to IOC Bill Lavender
- Download vxWorks to IOC chengwx
Shameless Plug For EDM (Extensible Display Manager) Mathias Steiner
<2000>
2025
2026
Re: Download vxWorks to IOC Andrew Johnson
<2000>
2025
2026
