1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PowerPC with MXI, MXI-2
Cc: EPICS tech-talk <[email protected]>, [email protected]
Date: Thu, 02 Nov 2000 10:46:25 -0500
Andrew Johnson wrote:
> Has anybody modified the EPICS VME-MXI-VXI driver to work on a PowerPC
> CPU?
> Has anybody modified the EPICS VME-MXI-VXI driver for the MXI-2 interface
> boards?
> If you or someone you know has worked on either of these, please let me
> know; I'd much rather not do either if I don't have to...
I originally developed a  non-EPICS VME-MXI-VXI driver for the MXI-2
interface on an MVME162 platform.   When we needed the same driver
to work with EPICS  on the MVME230x platform, I tried to compile the
VME-MXI-VXI driver which came with the EPICS release 3.13.1.1.  I
encountered  complications because that driver supports a wide range
of other interface hardware which I am not familiar with (e.g. NICPU030
and hpE1404).  Besides,  we need to have a new Fast Data Channel driver
to be incorporated into the EPICS VME-MXI-VXI driver for the MXI-2
in order to support our Tektronix TVS625/641 scopes.   At that moment,
to get my job done, it was easier for me to convert the non-EPICS driver I
wrote originally into the EPICS/PowerPC platform.
By using the makefile released with EPICS, I do not recall any PowerPC
related change during my VME-MXI-VXI driver conversion in the source codes.
I did have one problem with the Tektronix TVS625/641 scope driver
on the memcpy. However, the scope is working fine now.
If you have the EPICS driver working  specifically for the MXI-2 alreday, it
should be easy to convert it to the PPC platform.  If you are interested
in my codes, I will be glad to E-mail it to you.  Also,  you can check
the agenda of the EPICS workshop to be held in the Oak Ridge Lab..  I
recall there were some realated topics.
Cheers,
Kate
__________________________________________________________
S. Kate Feng                                                E-mail :
[email protected]
Brookhaven National Lab.
National Synchrotron Light Source
Bldg. 725D
Upton, New York  11973-5000
PowerPC with MXI, MXI-2 Andrew Johnson
Prev: PowerPC with MXI, MXI-2 Andrew Johnson
Next: Install MEDM on Linux OS, MEDM is installed with the EpicsExtensions RPM package Markus Schwoerer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
