1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GPIB Problems
To: [email protected]
Cc: [email protected]
Date: Mon, 13 Nov 2000 08:13:40 -0600 (CST)
Is the vxWorks board support you are booting for EPICS 3.13.2 different
from the one you are booting for 3.12.2? If so, are you sure the correct
changes were made in the BSP to map the 167 memory space for DMA
operation? This is a frequent trap when using any DMA VME board like the
NI014.
	Ned
> I am attempting to send commands through the EPICS GPIB interface with the
> GpibInteract program.  An error is returned by the 'sysLocalToBusAdrs'
> function in drvGpib.c, and I show the output of the GpibInteract program
> below.  The system was tested with a separate EPICS version (3.12.2) and
> functioned fine.  I am using version 3.13.2.
> Thanks,
> Robert Willson
> [email protected]
> Output from GpibInteract, running on MVME167 with VxWorks v.5.3
> Enter Message # to Send (1 thru 5) > 1
> 0x7aefc8 (tShell): niGpibIoctl(0, 8, 0, 00000000)
> 0x7aefc8 (tShell): niGpibIoctl(0, 9, 0, 007067FC)
> 0x7aefc8 (tShell): qgpibreq(0x007067DC, 2): transaction queued
> 0x5bf200 (ib-00): niSrqIntDisable(0): ch0.csr = 0x01, gsr=0xFFFFFFFF
> 0x5bf200 (ib-00): ibLinkTask(5, 0): got an event
> 0x5bf200 (ib-00): ibLinkTask(5, 0): got Hi Pri xact, pnode= 0x007067DC
> 0x5bf200 (ib-00): GI's gpibWork() was called for command >hvon<
> 0x5bf200 (ib-00): writeIb(0071A888, 5, 0x00706809, 4, 30)
> 0x5bf200 (ib-00): writeIbCmd(0071A888, 005BF17E, 4)
> 0x5bf200 (ib-00): niGpibCmd(0, 0x005BF17E, 4): command string >q
> 0x5bf200 (ib-00): niGpibWrite(0, 0x00706809, 4, 30)
> 0x5bf200 (ib-00): writeIbCmd(0071A888, 005BF17E, 2)
> 0x5bf200 (ib-00): niGpibCmd(0, 0x005BF17E, 2): command string >q
> 0x5bf200 (ib-00): niSrqIntEnable(0): ch0.csr = 0x01, gsr=0xFFFFFFFF
> Message #1 : LinkType=5 bug=0 Link=0 Adrs=5 Type=w
> Cmd: 00: 68 76 6F 6E                                          *hvon*
> Res: 00: 47 50 49 42 20 54 49 4D 45 4F 55 54 20 28 77 68      *GPIB
> TIMEOUT (wh*     10: 69 6C 65 20 74 61 6C 6B 69 6E 67 29
> *ile talking)*
> It looks like there is a problem in passing strings, niGpibCmd should
> print ?_%@ as its command string.
Prev: RE: Access security by IP number? Mark Rivers
Next: Streaming video of EPICS collaboration meeting Bill DeVan
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: GPIB Problems Robert Willson
Next: Access security by IP number? Susanna Jacobson
