1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ API backwards compatibility
Cc: EPICS-tech-talk <[email protected]>
Date: Thu, 07 Dec 2000 15:58:47 -0500
> to use an API that is compatible the the ISO/ANSI C++ standard library
  I've encountered code which purported to be compatible with
ISO/IEC 14882, but which in fact depended upon intentionally
undefined behavior.  Both g++ and MS VC++ quietly allow some
questionable constructs; how do you intend to verify that the
code adheres to the standard?
  Don't get me wrong: I'm all for it.  I just want to make
sure that everybody understands what "compatible with the
ISO/ANSI C++ standard" means.
Chris
Christopher A. Larrieu
Computer Scientist, Acc. Controls Group
Thomas Jefferson National Accelerator Facility
meetings Ian Smith
Re: C++ API backwards compatibility Andrew Johnson
C++ API backwards compatibility Jeff Hill
Prev: Re: C++ API backwards compatibility Andrew Johnson
Next: meetings Ian Smith
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
