1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposals for the Next Generation CA
To: "Jeff Hill" <[email protected]>
Cc: "EPICS Techtalk" <[email protected]>
Date: Thu, 14 Dec 2000 17:34:18 -0500
> > - Clients are free to specify any desired value as the monitor
> >   deadband, as long as the corresponding pv is triggering and its
> >   primitive type is a number.
> > - On successful connection to a pv, the server may suggest related pvs
> >   that contain suitable deadbands such as the corresponding MDEL and
> >   ADEL fields, if such fields exist.
> Only the server tool can decide on its own when its data has changed, and
> therefore an event should be posted. Otherwise, we are forced to poll the
> data from the server and introduce additional overhead and also
> propagation delays.
> It is however desirable in future versions to allow the client to specify
> a wider deadband than what is used by the server tool to decide if its PV
> has changed. This is already on the list.
How do you propose implementing this for IOC databases ?
The decision for whether to post a monitor is made by the record, not by
the server.
How do you handle a client that requests a *smaller* deadband than the one
defined in the record ? Are you suggesting that records always post
monitors and let the server decide whether to actually send them out ?
Sounds like it could be a real performance hit.
We use custom records that implement multiple MDEL- and ADEL-like fields,
which we of course had to define new names for.
How would that be supported ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
RE: Proposals for the Next Generation CA Jeff Hill
Prev: RE: EPICS R3.14 Jeff Hill
Next: base release 3.13.4 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposals for the Next Generation CA Benjamin Franksen
Next: Re: Proposals for the Next Generation CA Ned Arnold
