1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Asking for help about iocInit
To: <[email protected]>
Date: Sat, 23 Dec 2000 21:48:15 +0800
Dear Sir:
     I have make the EPICS base on Redhat6.2 successfully.
While downloading the vxWorks and EPICS database, the message is like this:
iocInit
IocLogClient:EPICS environment variable "EPICS_IOC_LOG_INET" undefined
iocLogClient:logging disabled
###@(#)EPICS IOC CORE
###@(#)Version R3.13.1..0$$Date:1998/11/19 16:18:25$$
Starting iocInit
I have define the environment in .../EPICS/base/config/CONFIG_SITE_ENV, so I
add this line in CONFIG_SITE_ENV:
EPICS_IOC_LOG_INET=***.***.***.***          /* here is my IP address*/
then make the EPICS base again, and using makeBaseApp to have a new application,
this time whiling loading , the message is:
iocInit
iocLogClient:unable to connect to Linux:7004 because "error=0x39"
I am puzzled on this message, can anybody tell me what does that error message mean?
And I have another question about the board Td4v(used in Timing system)
This board uses A32/D32 mode, out CPU card is MVME162. and the board's base address is
set to 0x21000000 . But after makeing the Device support and downloading, it tells that
the board can't be found//thinkhard
Is there any confliction of the board base address settings? Any suggestion is appreciated.
BTW: You are kindly enough if you can send a copy to my mail box while repling this mail.
Thank you very much
Cheng Weixing from SSRF(Shanghai Synchrontron Radiation Center),China
Re: Asking for help about iocInit Steven Hartman
Re: Asking for help about iocInit Maren Purves
Prev: Fwd: ISAC Achieves Full Energy Beam. Dave Gurd
Next: FW: CapFast Library for EPICS Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Asking for help about iocInit Steven Hartman
