> Steven Hartman wrote:
> > On Fri, 15 Dec 2000, Marty Kraimer wrote:
> > > Release 3.13.4 is now available.
> > I have experienced a problem with ca clients (including medm, probe, etc.)
> > compiled under 3.13.4 in connecting to PVs on 3.11 IOCs. The same clients
> > compiled using 3.13.3 work normally in connecting to these same PVs. For
> > example, using caExample (on a Solaris 7 host to get a PV residing on a
> > 3.11 ioc) . . .
> I dont think that anyone doing development still has access to any 3.11 systems.
> Thus it is not too surprising that your problem is occuring. Since none of the
> developer's have a 3.11 system available this may not be easy to fix.
Fortunately, there were very few changes between EPICS R3.13.3 and EPICS
R3.13.4.
I suspect that if you remove the if statement labeled "before" below
on line 1048 in the R3.13.4 epics/base/ca/service.c ()
and replace it with the code labeled "after" below
that you will find that R3.13.4 will connect properly with R3.11.
before:
> if ( piiu->state != iiu_connected ) {
> UNLOCK;
> return;
after:
if ( CA_V42( CA_PROTOCOL_VERSION, piiu->minor_version_number ) ) {
UNLOCK;
return;
Sorry about the inconvenience. As Marty undedicated it is very difficult to
test against very old releases.
I have tested this change with R3.13 servers. Please let me know if this change
works with R3.11 systems and I will commit it on the R3.13 patch branch.
I would also like to hear from any other sites that are still using an EPICS
release prior to R3.12.
Jeff
- RE: base release 3.13.4 Steven Hartman
- Re: base release 3.13.4 Marty Kraimer
<2000>
2025
2026
<2000>
2025
2026
