> we've tested the MVME162-P344E (wich should replace the old MVME162-
> 532a)together with EPICS.
> The good news is that the board was compatible to the old one regarding
> the BSP.
> The bad news is that we encountered interrupt problems which caused a
> reboot of the IOC after some ours.
> I talked with my distributor and he told me that the first series of the
> Petra ASCISs has definitively BUGs regarding interrupts. Therefore
> Motorola has replaced the Petra ASIC with a new one. As far as I know
> the boards with the new ASIC habe the letter 'A' after the 'P' . The new
> MVME162-P344E is now called MVME162-PA344E.
I just received an MVME162-P344E. I have an unrelated question regarding
how to program vxWorks into the Flash. I left the board in its factory
configuration of jumpers and switches and tried the example they give in the
manual of programming the Bug debugger into the Flash. I am working from
memory now, but I think the command was
pflash 8000000:800000 FFA00000
Bug printed out the addresses which would be programmed and they looked
correct. However, it then gave an error something like:
pflash error in address range
I am sure I typed exactly what was in the manual. I also tried programming
vxWorks from RAM to Flash using exactly the instructions which used to work
on the old MVME162. I got the same error.
What do I need to change from the factory default to allow Flash progamming
to work?
Mark Rivers
- RE: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
Re: EPICS runtime problems on Motorola mv162-P242E CPUs Joachim . Rahn
<2001>
2025
2026
<2001>
2025
2026
