1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: smoothing for AI Soft Records
To: [email protected]
Date: Mon, 19 Mar 2001 21:17:40 +0100
Bernd Schoeneburg wrote:
> If readValue () return with ERROR, udf should not be set to FALSE. If the device
> support read routine (called from readValue) returned '2' (don't convert) it should
> have reset udf. So I think moving of this resetting would break (or 'improve')
> existing device support code and is not nessecary. In mbbi-Record it's the same.
> Carl Lionberger wrote:
> > I agree this sounds OK.  I did notice there is a setting udf to false at the end
> > of convert() (after the smoothing).  I think it needs to either be deleted (its
> > set false various places in device support) or also moved to process().  Surely a
> > converted value is not considered more defined than a smoothed but not converted
> > one.
Is there some generally agreed upon rule which of record support or
device support should reset UDF? I remember I came onto this myself. My
impression has been that sometimes people put it in the device support
because it's missing in the record support (where IMHO it belongs).
Didn't we fix this for some of the records a while ago?
Ben
smoothing for AI Soft Records Brian McAllister
Re: smoothing for AI Soft Records Bernd Schoeneburg
Prev: Re: smoothing for AI Soft Records Bernd Schoeneburg
Next: Agilent E2050A access from non-EPICS applications Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
