1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Agilent E2050A access from non-EPICS applications
Cc: [email protected]
Date: Mon, 19 Mar 2001 15:39:38 -0600
Do you use non-EPICS applications to communicate with GPIB devices
through the Agilent E2050A GPIB/LAN adapter from Solaris or Linux
hosts?  If so, how do you do this?  I have not been able to find any
libraries that provide this access.  National Instruments provides a
Linux shared library to provide C-callable subroutines to communicate
with devices through their GPIB-ENET adapter, but Agilent provides
nothing comparable.
This causes a problem.  If I want to use non-EPICS applications (Tcl/Tk,
standalone C programs, etc.) on my Linux/Solaris machines I have to use
the GPIB-ENET adapter.  If I want to use EPICS applications I have to
use an E2050A.
I could use the excellent EPICS driver from Benjamin Franksen as a
starting place for implementing a library matching the National
Instruments API (ibfind, ibdev, ibrd, ...) but I'd like to avoid that
much work if I can!
Eric Norum                                 [email protected]
Department of Electrical Engineering       Phone: (306) 966-5394
University of Saskatchewan                 FAX:   (306) 966-5407
Saskatoon, Canada.
Re: Agilent E2050A access from non-EPICS applications Rod B. Nussbaumer
Re: Agilent E2050A access from non-EPICS applications Jens Eden (PTB)
smoothing for AI Soft Records Brian McAllister
Re: smoothing for AI Soft Records Bernd Schoeneburg
Prev: Re: smoothing for AI Soft Records Benjamin Franksen
Next: Re: Agilent E2050A access from non-EPICS applications Rod B. Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
