Eric Norum wrote:
> Do you use non-EPICS applications to communicate with GPIB devices
> through the Agilent E2050A GPIB/LAN adapter from Solaris or Linux
> hosts? If so, how do you do this? I have not been able to find any
> libraries that provide this access. ....
The E2050A GPIB/LAN adapter supports VXI-11 Protocol Spec., which describes the
communication between measurement devices via RPC-Calls. The document contains a
RPCL (RPC Language) protocol description, which you can use to generate client
and server C-code with rpcgen. I will send it to you (it's not much code, but
too
long for the tech-talk list), together with a small demo application from
Benjamin Franksen. He built the EPICS-driver around this.
Jens
- smoothing for AI Soft Records Brian McAllister
- Re: smoothing for AI Soft Records Bernd Schoeneburg
- Agilent E2050A access from non-EPICS applications Eric Norum
XYCOM XVME 203 Counter Module w/ Quadrature Kristi Luchini
Re: Archive for Tech-Talk Marty Kraimer
<2001>
2025
2026
Re: Agilent E2050A access from non-EPICS applications Marty Kraimer
Archive for Tech-Talk Leonard J. Reder
<2001>
2025
2026
