1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca client connection pattern
To: [email protected]
Date: Thu, 29 Mar 2001 11:00:12 -0600
I neglected to include an error message.  Here is the same command
(ca_test) issued three times in a row.
-> ld < ca_test.o
value = 67088952 = 0x3ffb238
-> ca_test "CTL_PROC_00/MEM"
Not Found CTL_PROC_00/MEM
value = -1 = 0xffffffff = dataMutex + 0xfc22c4f7
native type:    -1
native count:   0
CA.Client.Diagnostic..............................................
    Message: "The request was ignored because the specified channel is
disconnec
ted"
    Severity: Error
    Source File: ../ca_test.c Line Number: 193
< I hit ^C here >
178934 vxTaskEntry    +60 : shell ()
155cbc shell          +18c: 155ce8 ()
155ef0 shell          +3c0: execute ()
156070 execute        +d8 : yyparse ()
18ef78 yyparse        +7a8: 18cedc ()
18d054 yystart        +8f8: ca_test ()
3b790a0 ca_test        +18 : 3b79120 ()
3b79348 ca_test        +2c0: ca_signal_with_file_and_lineno ()
3c97eac ca_signal_with_file_and_lineno+12c: taskSuspend ()
tShell restarted.
native type:    6
native count:   1
DBR_STRING      57.60
DBR_SHORT       57
DBR_FLOAT       57.6009
DBR_ENUM        57
DBR_CHAR        57
DBR_LONG
57
DBR_DOUBLE      57.6009
DBR_STS_STRING   0  0   Value: 57.60
DBR_STS_SHORT    0  0   Value: 57
DBR_STS_FLOAT    0  0   Value: 57.6009
DBR_STS_ENUM     0  0   Value: 57
DBR_STS_CHAR     0  0   Value: 57
DBR_STS_LONG     0  0   Value: 57
DBR_STS_DOUBLE   0  0   Value: 57.6009
DBR_TIME_STRING  0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57.60
DBR_TIME_SHORT   0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57
DBR_TIME_FLOAT   0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57.6009
DBR_TIME_ENUM    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57
DBR_TIME_CHAR    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57
DBR_TIME_LONG    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57
DBR_TIME_DOUBLE  0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
57.6009
DBR_GR_STRING    0  0   Value: 57.60
DBR_GR_SHORT     0  0
             100        0       90       60        0        0   Value:
57
DBR_GR_FLOAT     0  0    2
         100.000    0.000   90.000   60.000    0.000    0.000   Value:
57.6009
DBR_GR_ENUM      0  0   Value: 57
DBR_GR_CHAR      0  0
57
DBR_GR_LONG      0  0
57
DBR_GR_DOUBLE    0  0    2
57.6009
DBR_CTRL_STRING  0  0   Value: 57.60
DBR_CTRL_SHORT   0  0
             100        0       90       60        0        0
100        0
Value: 57
DBR_CTRL_FLOAT   0  0    2
100.000    0.000
Value: 57.6009
DBR_CTRL_ENUM    0  0   Value: 57
DBR_CTRL_CHAR    0  0
             100        0       90       60        0        0
100        0
Value:   57
DBR_CTRL_LONG    0  0
             100        0       90       60        0        0
100        0
Value: 57
DBR_CTRL_DOUBLE  0  0    2
100.000    0.000
Value: 57.600948
value = 0 = 0x0
Geoff Savage wrote:
> Hi,
> I'm running a ca client on an ioc and connecting to pv on a different
> ioc.  On one boot of the processor the connection happens with no
> problems.  On the next boot of the processor the connection attempt
> fails.  This pattern has continued for the last two days.  The ca client
> processor is an mv2304 and pv processor has been an mv162 and mv2301.
> I have tested the connections between the processors with ping.
> Any ideas?
> Thanks
> Geoff
RE: ca client connection pattern Jeff Hill
ca client connection pattern Geoff Savage
Prev: ca client connection pattern Geoff Savage
Next: Re: ca client connection pattern Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: ca client connection pattern Jeff Hill
