1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ca client connection pattern
To: "Geoff Savage" <[email protected]>, <[email protected]>
Date: Thu, 29 Mar 2001 11:45:36 -0700
Geoff,
I am unable to reproduce the behavior you describe with
vxWorks 5.4 / pc486 BSP and EPICS R3.13.3 at our site.
Do you see this problem only with ca_test or do other IOC
initiated CA connections from the sequencer or the database
links also fail?
Does ca_test fail to connect to this IOC when it is run from
a workstation?
Does your network have many devices that are configured with
the wrong subnet mask. If so this can cause problems with
CA broadcasting based name resolution. This can be detected
if you run "snoop icmp" on a Solaris machine and you
see many ICMP destination unreachable responses to CA's
broadcasted attempts to find process variables.
I notice that the R3.14 version of ca_test has been upgraded to
call ca_clear_channel() and ca_task_exit() to clean up before it
returns. This might result in improved behavior under vxWorks.
Nevertheless, I was unable to reproduce your problem with the
earlier R3.13 version of ca_test on vxWorks 5.4.
Running a CA program on vxWorks directly from the shell can
be problematic because (on vxWorks 5.4) the shell by default
runs at one notch below the highest possible priority. This might
cause problems because CA spawns off various auxiliary threads
that run at priorities above and below the priority of the
initiating thread. You could avoid these problems
by spawning ca_test to run at a lower priority. Nevertheless, I
was unable to reproduce your problem with the earlier R3.13
version of ca_test initiating at the shells default priority
(on vxWorks 5.4 this is priority level 1). Imp not certain of
this, but I seem to recall that earlier version (possibly
your vxWorks 5.3.1) run the shell at the very highest priority
(priority level 0).
Make certain that the ca_test that you are using was compiled
against the same version of EPICS that you have loaded into your
IOC.
Jeff
> -----Original Message-----
> From: Geoff Savage [mailto:[email protected]]
> Sent: Thursday, March 29, 2001 10:00 AM
> To: [email protected]
> Subject: Re: ca client connection pattern
> I neglected to include an error message.  Here is the same command
> (ca_test) issued three times in a row.
> -> ld < ca_test.o
> value = 67088952 = 0x3ffb238
> -> ca_test "CTL_PROC_00/MEM"
> Not Found CTL_PROC_00/MEM
> value = -1 = 0xffffffff = dataMutex + 0xfc22c4f7
> native type:    -1
> native count:   0
> CA.Client.Diagnostic..............................................
>     Message: "The request was ignored because the specified channel is
> disconnec
> ted"
>     Severity: Error
>     Source File: ../ca_test.c Line Number: 193
> < I hit ^C here >
> 178934 vxTaskEntry    +60 : shell ()
> 155cbc shell          +18c: 155ce8 ()
> 155ef0 shell          +3c0: execute ()
> 156070 execute        +d8 : yyparse ()
> 18ef78 yyparse        +7a8: 18cedc ()
> 18d054 yystart        +8f8: ca_test ()
> 3b790a0 ca_test        +18 : 3b79120 ()
> 3b79348 ca_test        +2c0: ca_signal_with_file_and_lineno ()
> 3c97eac ca_signal_with_file_and_lineno+12c: taskSuspend ()
> tShell restarted.
> native type:    6
> native count:   1
> DBR_STRING      57.60
> DBR_SHORT       57
> DBR_FLOAT       57.6009
> DBR_ENUM        57
> DBR_CHAR        57
> DBR_LONG
> 57
> DBR_DOUBLE      57.6009
> DBR_STS_STRING   0  0   Value: 57.60
> DBR_STS_SHORT    0  0   Value: 57
> DBR_STS_FLOAT    0  0   Value: 57.6009
> DBR_STS_ENUM     0  0   Value: 57
> DBR_STS_CHAR     0  0   Value: 57
> DBR_STS_LONG     0  0   Value: 57
> DBR_STS_DOUBLE   0  0   Value: 57.6009
> DBR_TIME_STRING  0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57.60
> DBR_TIME_SHORT   0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57
> DBR_TIME_FLOAT   0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57.6009
> DBR_TIME_ENUM    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57
> DBR_TIME_CHAR    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57
> DBR_TIME_LONG    0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57
> DBR_TIME_DOUBLE  0  0   TimeStamp: 03/29/01 10:52:12.908292763  Value:
> 57.6009
> DBR_GR_STRING    0  0   Value: 57.60
> DBR_GR_SHORT     0  0
>              100        0       90       60        0        0   Value:
> 57
> DBR_GR_FLOAT     0  0    2
>          100.000    0.000   90.000   60.000    0.000    0.000   Value:
> 57.6009
> DBR_GR_ENUM      0  0   Value: 57
> DBR_GR_CHAR      0  0
> 57
> DBR_GR_LONG      0  0
> 57
> DBR_GR_DOUBLE    0  0    2
> 57.6009
> DBR_CTRL_STRING  0  0   Value: 57.60
> DBR_CTRL_SHORT   0  0
>              100        0       90       60        0        0
> 100        0
> Value: 57
> DBR_CTRL_FLOAT   0  0    2
> 100.000    0.000
> Value: 57.6009
> DBR_CTRL_ENUM    0  0   Value: 57
> DBR_CTRL_CHAR    0  0
>              100        0       90       60        0        0
> 100        0
> Value:   57
> DBR_CTRL_LONG    0  0
>              100        0       90       60        0        0
> 100        0
> Value: 57
> DBR_CTRL_DOUBLE  0  0    2
> 100.000    0.000
> Value: 57.600948
> value = 0 = 0x0
> Geoff Savage wrote:
> > Hi,
> > I'm running a ca client on an ioc and connecting to pv on a different
> > ioc.  On one boot of the processor the connection happens with no
> > problems.  On the next boot of the processor the connection attempt
> > fails.  This pattern has continued for the last two days.  The ca client
> > processor is an mv2304 and pv processor has been an mv162 and mv2301.
> > I have tested the connections between the processors with ping.
> > Any ideas?
> > Thanks
> > Geoff
Re: ca client connection pattern Geoff Savage
Prev: medm window resizing Paul Sichta
Next: Re: ca client connection pattern Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ca client connection pattern Geoff Savage
