1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Interrupt on MV2302
To: <[email protected]>
Date: Mon, 16 Apr 2001 09:40:56 +0800
hello, There has something with my system when using interrupt.
The system is like this :
Mv2302 CPU board + Avme9321 12 bit I/O card.
I tried to use External Trigger of Avme9321 and wrote a simple pure vxWorks program:
#include <vxWorks.h>
#include <stdio.h>
#include <stdioLib.h>
#include <sockLib.h>
#include <inetLib.h>
#include <strLib.h>
#include <ioLib.h>
#include <intLib.h>
#include <iv.h>
#define Base_Addr 0xfbff0000
void init();
void test();
void isr();
void init()
unsigned char * pointer;
pointer=Base_Addr+0x83;
*pointer=0xe0;      /* set the interrupt vector register*/
pointer=Base_Addr+0x81;
*pointer= 0x10;          /* Board Software reset*/
*pointer=0x0B;          /*board int enable*/
pointer=Base_Addr+0x85;
*pointer=0x10;            /* board control register*/
printf("init finished now\n");
void test()
init();
if(intConnect(INUM_TO_IVEC(0xe0),isr,0)==OK) /* intVector is set to 0xe0*/
printf("connect OK\n");
else
printf("Error\n");
sysIntEnable(4);        /* int level set to 4*/
printf("the status reg is %x\n",*pointer);
return OK;
void isr()
 *pointer=0x03;  /*int disable*/
 sysIntDisable(4);
 logMsg("The isr is running...\n");
 *pointer=0x0B;  /*int enable*/
 sysIntEnable(4);
 return OK;
make and ld it. run test() routine. and then I give a external trigger to Avme9321. the
message is like this:
Interrupt: The isr is running
Interrupt: T
                                         /* it seems the isr is runing, but only
                                         last for several times and get a overflow message,
                                          and reboot the system*/
WorkQPanic: Kernel work queue overflow        /* what does this mean? */
then the system reboot automatically, I don't know what's wrong with it. the External Trigger is
only a 1Hz square wave. Can any of you give me some advice ? Thank you.
Cheng Weixing from SSRF
Re: Interrupt on MV2302 Marty Kraimer
Prev: Re: CAN questions Bernd Schoeneburg
Next: help about PENTEK 4284/4257 module? shen guobao
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CAN questions Benjamin Franksen
Next: Re: Interrupt on MV2302 Marty Kraimer
