1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAN questions
To: tech-talk <[email protected]>
Date: Fri, 13 Apr 2001 22:48:02 +0200
At DESY we use commercial I/O modules with CanOpen communication connected
to a TIP810 CAN-IP. Our EPICS driver/device support can work with CanOpen
and Can (Layer2) devices as well. The driver works with the Ipac-Api. It
supports only basic functions of CanOpen but for simple I/O it's ok.
We had some bad experience with a analogue input module running in i/o-event
mode. But this wasn't a CAN-problem. The bus is very secure. A disadvantage
is that because of bitwise arbitration the speed must be reduced drastically
if the length of the bus becomes longer.
Bernd
John Maclean wrote:
> At the APS we are considering adopting CAN for one of our applications
> requiring some remote I/O.
> This particular project needs ~32 binary I/O channels and ~6 low res. (8
> to 12 bit) analog inputs per node.
> Is any one already using a similar off-the-shelf solution, or do people
> generally build their own custom CAN board? Is anyone interfacing
> CANopen or DEVICEnet products to EPICS?
> Someone, (management), also asked me if I knew of anyone who's had a bad
> experience with CAN. I didn't, but as a matter of interest I'd be
> interested to hear of any experiences with CAN, either bad or good.
> Thanks,
> John.
CAN questions John Maclean
Prev: Re: CAN questions Rolf Keitel
Next: Interrupt on MV2302 Weixing Cheng
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CAN questions Benjamin Franksen
