> > > > I have immensely enjoyed looking at the $(EPICS_BASE)/config/RULES.Vx MAKE instructions.
> > > Given the increasing complexities of C++ development we were thinking of rewriting
> > > all of EPICS for execution by the GNU make interpreter. An obvious advantage would
> > > be a reduction in the complexity of the build system. What do you think?
> > Having built and watched others build EPICS, I think this would be a *very* welcome
> > change.
> > As for the implementation, I am guessing you mean using the standard GNU configure
> > build. Is that what you are suggesting?
> Sorry about the confusion. The above was an attempt at some ( possibly
> warped ) dry humor.
Well, it's Monday morning here, and I think I'll need another cup of
coffee before I wake up :-)
> incomprehensible machine generated low level Makefiles. The gnu build
> system is also very complex, it is very much chained to UNIX, and it
> tends to ( as I understand it ) port software by encouraging the build
> system to modify the source code. Not my favorite approach.
I am not aware of this. I understand it searches for tools and defines
them in a makefile that it modifies.
>From a user's perspective, it is very simple, as anyone who has installed
GNU tools would attest. From a maintainer's perspective, I don't think
it's too bad either -- but it always depends on what you're used to.
I don't think it easily supports a Win32 build, however. And I think
the Cygnus installation installs some tools to make DOS look like more
like a UNIX environment, and uses that environment for building, not
the vanilla DOS environment.
> The systems strong points are its operating system
> independence, and the low effort required to introduce a new architecture.
> I suspect that our system is very unique in that we are able to use the same
> Makefiles for both UNIX and MS Windows.
But should this be a design goal, considering the cost in complexity? Or
perhaps reverting to maintaining two simpler make systems could be
reconsidered? (Just asking. I of course have not considered this as
carefully as y'all have, but I have worked with software that has
adopted this philiosophy, so there's some reasonableness to the
suggestion.)
> In R3.14 this set is expanded to
> include RTEMS and vxWorks. Its difficult to reach these goals without some
> complexity, and also without introducing some constraints on the application's
> Makefiles.
> One goal of the build system was to, where ever possible, move complexity
> out of application makefiles, and into the build system. Consequently,
> the system's internals _are_ very complicated, and if the answers are not
> obvious while introducing off normal application Makefile syntax, then it
> might be best to discuss your situation with someone that works with the
> build system internals every day. In any case thats what I do.
Thanks! I appreciate the offer. One thing that is great about this build
system is the support behind it.
RE: Fun with MAKE Peter Kurpis
RE: Fun with MAKE Jeff Hill
<2001>
2025
2026
CA problem while using EVENT I/O Cheng Weixing
<2001>
2025
2026
