1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: longoutRecord Bug
To: Eric Bjorklund <[email protected]>
Cc: [email protected]
Date: Wed, 25 Apr 2001 10:04:31 +0000
Hi Eric,
Yes, I noticed this too and have "spoken" (over E-mail) with
Marty about it.
There are other records which exhibit the same feature, namely:
dfanout, stringout, steppermotor.
All have code similar to the longout with respect to the DOL
link. What I did was changed the longout and others to be like
this:
     if (!plongout->pact) {
             if( (plongout->dol.type != CONSTANT) && (plongout->omsl ==
CLOSED_LOOP)) {
                     status = dbGetLink(&(plongout->dol),DBR_LONG,
                             &value,0,0);
                     if (plongout->dol.type!=CONSTANT &&
RTN_SUCCESS(status))
                             plongout->udf=FALSE;
             else {
                     value = plongout->val;
             if (!status) convert(plongout,value);
Then for a CONSTANT DOL type, the value gets initialized as it does
in an ao record.
Cheers,
Andy
Eric Bjorklund wrote:
> I appear to have discovered a bug in longoutRecord.c under R3.13.4 which
> probably dates back to R3.13.3, when the drvh & drvl fields were added.
> The manifestation is that a longout record with OMSL in closed_loop and
> a constant value in the DOL link, will end up with an arbitrary value
> in VAL when the record is processed.
> The culpret is in the following code from the "process" routine:
>             if (plongout->omsl == CLOSED_LOOP) {
>                             &value,0,0);
>                     if (plongout->dol.type!=CONSTANT && RTN_SUCCESS(status))
>             else {
> If dol.type is CONSTANT, dbGetLink does not fetch the link value, and so
> the variable "value" is never initialized.
> The fix, I've implemented for now is to initialize "value" in its declaration
> at the begining of the process routine, i.e:
>         long             value=plongout->val;
> This restores the longout record to its previous behavior -- which is not
> the same as, for example, an ao record with the similar setup since it
> allows you to change the value by writing to the VAL field.  For that, however,
> we'd probably have to add another field to longout (such as the ao's PVAL
> field).
> Eric Bjorklund
> LANSCE-6 Controls
> Los Alamos Neutron Scattering Center.
> [email protected]
Observatory Sciences Limited		Email: [email protected]
William James House			Tel:  44 - (0)1223 - 508257
Cowley Road			Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK		http://www.observatorysciences.co.uk
Re: longoutRecord Bug Marty Kraimer
longoutRecord Bug Eric Bjorklund
Prev: Problems with GSOctalRS232 Leng Yongbin
Next: Re: longoutRecord Bug Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: longoutRecord Bug Eric Bjorklund
