Leng Yongbin wrote:
> So we select a solution consisting of MVME2302, VIPC616, and GSOctal IP module. We also download the Ipac2.2 package.
> But we failed set up this device driver from within a vxWorks startup script. The information is as follows:
> ipacAddCarrier &vipc616,"0x6000"
> value = 0 = 0x0
> MODO = tyGSOctalModuleInit("GSIP_OCTAL232",0x80,0,0)
> 0x1bef5d0 (tShell): tyGSOctalModuleInit: No memory allocated for carrier
The last line above is a hint to your problem. The GreenSpring Octal232
module needs more register space than is normally available in the IPAC
module Register area, so it also needs the carrier to provide some memory
space for its interrupt vector register. There are jumpers on the VIPC616
that set the A24 base address for the IPAC memory space (I strongly
suggest you do not use A32 space because that will need changes to your
vxWorks build). You will also need to provide additional arguments in the
ipacAddCarrier initialization string to tell the carrier driver where and
how much memory you have set them up for - use the smallest 64KB setting,
and read the VIPC616 section of the drvIpac documentation for details.
- Andrew
Every great idea appears crazy to start with.
- Problems with GSOctalRS232 Leng Yongbin
Re: longoutRecord Bug Marty Kraimer
RE: Problems with GSOctalRS232 Mark Rivers
<2001>
2025
2026
<2001>
2025
2026
