Dear All,
Has anyone experienced a task crash caused by the "devVXStats" support
in 3.13.4?
I have just added the database records for this. I'm running on
an MVME2700 PPC. The system is apparently about 7% loaded according
to the report from the device support. I'm sampling the CPU load every
5 seconds, although I have varied this with the same outcome.
I traced the crash to line 373 of "devVXStats.c" (in the function "getCpu"):
temp = 100.0 * temp/ticksNow;
It appears to be possible for "ticksNow" to be 0 at this point.
I added a conditional check on "pcpuUsage->ticksNow" so that the code
only gets executed if this value is non-zero (adding a printf statement so
that I could see how many crashes I would have had):
static double getCpu()
if((pcpuUsage->didNotComplete && pcpuUsage->nBurnNow==0) || !pcpuUsage->ticksNow) {
if( !pcpuUsage->ticksNow )
printf("This would have been a crash\n");
pcpuUsage->usage = 0.0;
} else {
double temp;
double ticksNow,nBurnNow;
ticksNow = (double)pcpuUsage->ticksNow;
nBurnNow = (double)pcpuUsage->nBurnNow;
ticksNow *= (double)pcpuUsage->nBurnNoContention/nBurnNow;
temp = ticksNow - (double)pcpuUsage->ticksNoContention;
if(temp<0.0 || temp>100.0) temp=0.0;/*take care of tick overflow*/
pcpuUsage->usage = temp;
pcpuUsage->didNotComplete = TRUE;
semGive(pcpuUsage->startSem);
return(pcpuUsage->usage);
I saw the statement about 4 times in 1 hour on the console.
I'm not sure why "pcpuUsage->ticksNow" is zero, but I think it might be
worth adding in the check just to be defensive.
Cheers,
Andy
Observatory Sciences Limited Email: [email protected]
William James House Tel: 44 - (0)1223 - 508257
Cowley Road Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- Re: devVXStats and task crash Marty Kraimer
Re: gdct built with ivtools - bug Kristi Luchini
New MCP750s That Don't Run VxWorks Boot Code Susanna Jacobson
<2001>
2025
2026
<2001>
2025
2026
