1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RAMIX RM139 memory board and PowerPC
To: Tech-Talk <[email protected]>
Date: Fri, 27 Apr 2001 17:36:22 -0500
We have a Ramix RM139m memory board working with an mv167 CPU and we now
want to use it with a PowerPC. Has anyone tried this before?
Attached to this message are the modifications made to all/usrConfing.c
and mv167/sysLib.c to make the RAMIX board work with the mv167. Any
suggestions on how to get it done with the PowerPC will be appreciated.
Thank you,
Pedro Gigoux
Gemini Observatory
-- all/usrConfig.c modifications
#define SHORTIO     0xffff0000
#define RM139SHORT  (SHORTIO + 0x0100)
void usrInit
    int startType
#if	(CPU_FAMILY == SPARC)
    excWindowInit ();				/* SPARC window management */
#endif
    int index;
    unsigned short *target;
      Initialization values for RAMIX RM139 Memory board - KJR
    int rm139Config[7][2] =
    {{(RM139SHORT + 0x00), 0x0040}, /* R0  VME Low        */
     {(RM139SHORT + 0x02), 0x00C0}, /* R1  VME High       */
     {(RM139SHORT + 0x04), 0x3b39}, /* R2  A24 Add. Mod.  */
     {(RM139SHORT + 0x06), 0x38},   /* R3  A24/D64 Mod.   */
     {(RM139SHORT + 0x08), 0x0b0d}, /* R4  A32 Add. Mod.  */
     {(RM139SHORT + 0x0a), 0x08},   /* R5  A32/D64 Mod.   */
     {(RM139SHORT + 0x16), 0x00}};  /* R11 Parity Control */
       Initialize RM139 memory board with 64 MB of memory.
       This code based on an example from the RM139 User's Manual - KJR
    for(index = 0;index < 7;index++)
	target = (unsigned short *) rm139Config[index][0];
	*target = rm139Config[index][1];
void usrRoot
    char *	pMemPoolStart,		/* start of system memory partition */
    unsigned	memPoolSize		/* initial size of mem pool */
    int  ix;
    /* Initialize the memory pool before initializing any other package.
     * The memory associated with the root task will be reclaimed at the
     * completion of its activities.
#ifdef INCLUDE_MEM_MGR_FULL
    memInit (pMemPoolStart, memPoolSize);	/* initialize memory pool */
#else
    memPartLibInit (pMemPoolStart, memPoolSize);/* initialize memory pool */
#endif /* INCLUDE_MEM_MGR_FULL */
#ifdef	INCLUDE_SHOW_ROUTINES
    memShowInit ();				/* initialize memShow routine */
#endif	/* INCLUDE_SHOW_ROUTINES */
#if	defined(INCLUDE_MMU_BASIC) || defined(INCLUDE_MMU_FULL)
    usrMmuInit ();				/* initialize the mmu */
#endif	/* defined(INCLUDE_MMU_BASIC) || defined(INCLUDE_MMU_FULL) */
    /* Define RAMIX memory board to system - kjr */
    memAddToPool((char *)0x4000000, 0x8000000);
-- mv167/sysLib.c modifications
PHYS_MEM_DESC sysPhysMemDesc [] =
    /* adrs and length parameters must be page-aligned (multiples of 0x2000) */
    /* ram */
    (void *) LOCAL_MEM_LOCAL_ADRS,
    0x1000000,				/* 16 Mbytes (adjust if necessary) */
    VM_STATE_MASK_VALID	| VM_STATE_MASK_WRITABLE | VM_STATE_MASK_CACHEABLE,
    VM_STATE_VALID	| VM_STATE_WRITABLE	 | VM_STATE_CACHEABLE
    /* vme  64 Mbytes - RAMIX board */
    (void *) 0x4000000,
    (void *) 0x4000000,
    0x8000000,
    VM_STATE_VALID	| VM_STATE_WRITABLE	 | VM_STATE_CACHEABLE_NOT
Prev: Re: devVXStats and task crash Marty Kraimer
Next: Re: dbCaLink and broadcast messages Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbCaLink and broadcast messages Kevin Tsubota
Next: EPICS Meeting next week Kay-Uwe Kasemir
