1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Input records with no device support
To: [email protected]
Cc: [email protected]
Date: Mon, 11 Jun 2001 08:58:14 -0500
"J. Frederick Bartlett ([email protected])" wrote:
>   After diligently searching the "Application Developer's Guide", the
> "Record Reference Manual", and the EPICS tutorials, I cannot find the
> answer to this question or an example that would answer it.
>   I wish to instantiate an input record (say, ai) that has no device
> support. I plan to set the VAL field from a process on the IOC using a
> runtime database access routine (dbPutField) and force the record to
> process -- and thereby trigger a change-of-value monitor -- by calling
> dbProcess. The question is: what do I put in the DTYP and INPUT fields
> of the record when I define it in a .db file?
If neither field is defined the default is to use devAiSoft (DTYP = "Soft
Channel") and a constant value of 0 (INP = "0").
Marty Kraimer
Input records with no device support J. Frederick Bartlett ([email protected])
Prev: Re: Input records with no device support Steven Hartman
Next: Re: Input records with no device support Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Input records with no device support Marty Kraimer
Next: Attaching other interface after VxWorks boot Vladis Korobov
