1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Input records with no device support
To: Steven Hartman <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 11 Jun 2001 09:05:03 -0500
Steven Hartman wrote:
> On Fri, 8 Jun 2001, J. Frederick Bartlett ([email protected]) wrote:
> > dbProcess. The question is: what do I put in the DTYP and INPUT fields
> > of the record when I define it in a .db file?
> If I understand correctly . . .
> record(ai,"foo") {
>         field(DTYP,"Soft Channel")
>         field(INP,"")
> where INP is a constant with no initial value.
> Steve Hartman
> [email protected]
> Duke Free Electron Laser Laboratory
This is a better answer than the one I gave. There is a difference between
    field(INP,"")
and
    field(INP,"0")
devAiSoft has the statements
static long init_record(pai)
    struct aiRecord     *pai;
    /* ai.inp must be a CONSTANT or a PV_LINK or a DB_LINK or a CA_LINK*/
    switch (pai->inp.type) {
    case (CONSTANT) :
        if(recGblInitConstantLink(&pai->inp,DBF_DOUBLE,&pai->val))
            pai->udf = FALSE;
        break;
Thus for field(INP,"") udf will not be set FALSE but for field(INP,"0") it will
be set false.
Marty Kraimer
Re: Input records with no device support Steven Hartman
Prev: Re: Input records with no device support Marty Kraimer
Next: Attaching other interface after VxWorks boot Vladis Korobov
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Input records with no device support Steven Hartman
Next: Re: Input records with no device support Marty Kraimer
