Dear Benjamin,
Thanks for the kudos.
Yes, I have got the "Warning: Port property "typ(U0)" should not equal
"val"." message. Once I realized that I could leave the type as val and get
a working database, I decided to ignore it. I only fixed these bugs because
I desperately had to in order to meet a looming deadline. Maybe next year I
will have time to look at these non-fatal problems, but not until then
unless they grow poisonous fangs and become fatal. Ahhh, the joys of
collaborative software!
Cheers,
Russell O. Redman
-----Original Message-----
Sent: Wednesday, June 13, 2001 2:50 PM
To: EPICS Techtalk
Subject: Re: Bug in e2db
Redman, Russell O. wrote:
> There is a stylistic issue in that the for loop tests for the completion
of
> the loop using "flink != 0", instead of "flink != NULL". Practically,
they
> are the same test but since pointers are (or should be) initialised to
NULL,
> they should also be tested against NULL. This stylistic defect occurs in
a
> variety of places throughout the program.
Just a little side-remark: I got the impression people will NEVER EVER
agree wether to use 0 or NULL. Matter of style, as you said. [Personally
I like to use 0 (zero) because comparison reduces to logical test i.e.
if(p) instead of if(p != 0) which is redundant. AFAIK, C language
definition garuantees this to work as expected.]
You are right, however, that choice should be consistent, i.e.
initialization same as comparison.
Much more important: Good job done, debugging e2db!
While you're at it, have you ever got error message like following:
---- Loc: motor:slider
Warning: Port property "typ(U0)" should not equal "val".
Warning: Port property "val(U0)" does not exist, treating as field ref.
Always appears if you use a free port, assign it some record field and
connect the port to something.
Problem is when you fix it, it breaks. Meaning *with* error message
produces correct db, but if you chose "path" for port property you get
wrong result. Took me quite a while then, to find out what was wrong:
why, my links simple weren't there after I "fixed" it.
Ben
- Re: Bug in e2db Benjamin Franksen
<2001>
2025
2026
<2001>
2025
2026
