1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bug in e2db
To: EPICS Techtalk <[email protected]>
Date: Thu, 14 Jun 2001 01:39:29 +0200
Hi Russell,
> Yes, I have got the "Warning: Port property "typ(U0)" should not equal
> "val"." message.  Once I realized that I could leave the type as val and get
> a working database, I decided to ignore it.  I only fixed these bugs because
> I desperately had to in order to meet a looming deadline.  Maybe next year I
> will have time to look at these non-fatal problems, but not until then
> unless they grow poisonous fangs and become fatal.  Ahhh, the joys of
> collaborative software!
Sniff, too bad :( You know, I remember taking a look at the code when I
encountered this the first time. I was not happy to see how rather
complicated this e2db thingy is. Probably weren't the first person who
did and decided the same as you i.e. ignore it.
One day...
Cheers,
Ben ;-)
PS: The "FATAL error" with frame around schematic appeared here only
after we (recently) upgraded to a new CapFast version. With previous
version it didn't happen because of error in sch2edif (frame was not in
edif file) and so floats up as e2db problem only now.
But nobody minds: Old version had such a horrible performance. Had to
run it as remote X-client since program was strictly tied to an ancient
machine due to company's strange licensing policy and the beast had
absolutely *no* optimization of repaint events. Drives you crazy to see
schematic slooowly repainted a hundred or so times whenever you forgot
again that you MUST NOT drag another window across it. Can you believe
how much I loved CapFast?
RE: Bug in e2db Redman, Russell O.
Prev: RE: Bug in e2db Redman, Russell O.
Next: Re: Attaching other interface after VxWorks boot Vladis Korobov
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: OSF bug Geoff Savage
