1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm updates
To: [email protected]
Cc: [email protected]
Date: Fri, 22 Jun 2001 08:34:47 -0500 (CDT)
medm only updates when a "monitor" is posted by the record for the field
that has changed while a caget retrieves the current value. Most record
support takes care of posting monitors for you, but for a subroutine
record it is <sometimes> up to you.
You don't mention which field in the subroutine record is causing the problem,
but it is likely a field in which the record support does NOT do a
     db_post_events(psub,&psub->field,monitor_mask);
If so, you will have to do one in your subroutine code whenever the value
changes. Examples abound in base/src/rec
	Ned
> Hello,
> I am running EPICS version R3.12.2 and MEDM version 2.3.3.
> Sometimes in MEDM the text monitor for a subroutine record specifies a
> different value than the one I can read via caget or dbpr or the PV info
> window. Anybody has an explanation ? A fix ?
> Thanks,
> 	Gaspare
>  ### Gaspare Lo Curto	office 234	| Telephone: + 49 89 32354226  ###
>  ### Max Planck Institut fuer Physik	| Fax:       + 49 89 3226704   ###
>  ### Foehringer Ring 6			|
>  ### D-80805 Munich      GERMANY	|			       ###
>  Now at Brookhaven National Laboratory, Upton, NY USA, ph: +1 631 344 3121
Prev: medm updates Gaspare Lo Curto
Next: [no subject] Mythili Srinivasan
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
