The archiver is not failing to receive events. My interpretation
of archive data was incorrect. It appears that when a PV disconnects
the archiver generates data but when the PV reconnects no data is
generated when the PV value did not change. This results in the
following:
07/23/2001 04:49:10.000000000 OFF Repeat 19731
07/23/2001 04:49:15.009771252 ON
07/23/2001 15:13:40.000000000 ON Repeat 3747
07/23/2001 15:13:48.706195000 - Disconnected
07/23/2001 15:51:59.035355000 - Disconnected
07/23/2001 15:55:48.541504844 ON
07/23/2001 16:39:00.000000000 ON Repeat 260
07/23/2001 16:39:01.606623000 - Disconnected
07/27/2001 13:20:06.997712000 - Disconnected
07/27/2001 13:55:14.999999800 OFF INVALID UDF
07/27/2001 20:06:40.000000000 OFF Repeat 2229
07/27/2001 20:06:45.015774866 ON
07/27/2001 20:07:50.000000000 ON Repeat 7
So, using the LibIO API, if I ask for data prior to 07/27/2001 13:20:06 I
may get a record which is again invalid. One therefore must keep going
back until a valid record is obtained.
I would argue for the generation of a data record when the PV reconnects.
John
On Mon, 30 Jul 2001, john sinclair wrote:
> We are using the following version of the Channel Archiver:
> Version 1.6.3, built Apr 6 2001, 13:33:59
> The engine has been logging date since 6/8/01 and at some point in the
> last two weeks has stopped receiving events for a number of PVs.
> The IOC is running R3.13.1.
> The client was built with R3.13.3.
> Are there any known problems that can explain this behavior?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
John Sinclair
[email protected]
- Channel Archiver john sinclair
Re: Error Message Paul Sichta
VMIC 4145 Support Garrett D. Rinehart
<2001>
2025
2026
Re: VxWorks kernel configuration for GPIB Andrew Johnson
<2001>
2025
2026
