Steve,
drvSerial is commonly used with drvAscii/devAscii layer that
supports a fairly generic command and response system. An up to date
version can be obtained from Allan Honey at Keck
([email protected]). drvSerial itself provides device
independent support for (named) serial devices.
The devNode/devNode package is a simple layer that uses drvSerial.
It is not nearly as robust as drvAscii/devAscii, although does
handle the case of multiple response delimiters, which drvAscii
does not. Unless you have a very strange device (like the legacy
control system we were talking to for the CFHT application)
I'd recommend use of drvAscii instead.
The tyGsOctal software does not _require_ use of drvNode, or even
drvSerial for that matter.
Steven Hartman wrote:
> Is source code for drvNode, devNode and drvSerial still available?
> I am looking into using Andrew Johnson's drvIpac with tyGSOctal for serial
> communication using SBS IP-OctualUART-232 modules mounted on a SBS VIPC616
> carrier board. It appears that this configuration will also require
> devNode and drvNode and maybe drvSerial?
> The links for devNode and drvNode
> (ftp://ftp.cfht.hawaii.edu/pub/tcs/epics/) are no longer valid.
> Thanks,
> Steve Hartman
> [email protected]
> Duke Free Electron Laser Laboratory
Aloha,
Peregrine
Peregrine M. McGehee [email protected] (505) 667-3273
Spallation Neutron Source - Global Controls (SNS-4)
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- devNode, drvNode, drvSerial source? Steven Hartman
mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
<2001>
2025
2026
RE: devNode, drvNode, drvSerial source? Porter, Rodney
<2001>
2025
2026
